overheating issue.. any idea?
Old Aug 8, 2004 | 02:20 PM
timbo79's Avatar
timbo79
Default overheating issue.. any idea?
Looking for feedback.. 2000 M6 29k miles... 160 stat and reprogrammed fans. Car has been running like a top and outr of the blue, temp was rising. hit 255 and I cooled off and it did it again. Thought the thermo stuck.. replaced followed procedure for filling again, idle, cap, rev, top off, repeat, etc... still overheat. did the procedure again. drove to test.. hit 180- up to 200, then fell to 179 again.. then boom, slowly rose to higher temp bang 250 again.... fans are working perfectly, if the h20 pump was out I would know it.. Do I have air in the system? Comments would be appreciated. I am sure someone else has had this happen I still have 2.5 years left on warranty, but of somethng simple, well. it is Sunday.
Thanks in advance all..
Old Aug 8, 2004 | 02:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
did I read it right?? you replaced the T-stat and it still does it??
maybe it is sticking intermittently???
is there anything clogging your radiator plastic bag or something keeping air from circulating??
chocoholic's Avatar
chocoholic
Somewhat obvious I know, but did you check that you don't have something stuck to the front of the radiator?
Old Aug 8, 2004 | 06:01 PM
timbo79's Avatar
timbo79
checked for stuck bags, etc.. nada.. nothing.. very strange... only other thing I can think of is water pump, but I think my belt would have a problem moving.
Thanks all.... any other ideas of what to look at let me know....
Old Aug 8, 2004 | 06:57 PM
AU N EGL's Avatar
AU N EGL
Also take a high pressure air hose and blow out the sand and dirt out of the radiator fins.
Old Aug 8, 2004 | 10:49 PM
alanh's Avatar
alanh
A couple of other possibilities along with everything else mentioned above, the temp sensor could be giving you false readings and while the guage goes up, it may not actually be hot at all.
The water pump impeller can come loose from the shaft and not be pumping water properly. This is the least likely thing to happen, but it can happen to water pumps.
Old Aug 9, 2004 | 03:40 AM
[ Ls1 ]'s Avatar
[ Ls1 ]
Default hey check ur heater
when your car is overheating turn on your heater and see if you get heat...if you dont then u have a clogged ac line...which can cause air pockets in the block...air heats up quicker than coolant so if a temp sensor is in a pocket, it will get high readings...if this is ur problem the answer is to clean out your ac lines...then fill up the block from the top radiator hose to eliminate the air pockets in the block...then run engine with coolant cap off..untill all air is released then ur done...
Old Aug 9, 2004 | 02:24 PM
timbo79's Avatar
timbo79
Thanks again. Yes.. hot air from heater is coming out. I think it is bad sensor I am bringing it in later today to get it checked. Thank God for extended warranties... I will let all know what the problem is when I know Thanks again
To overheating issue.. any idea?
