2000 Corvette problems...
Old Aug 27, 2004 | 08:56 PM
Sleepy1981's Avatar
Sleepy1981
5th Gear
Default 2000 Corvette problems...
Hi!
Yesturday I noticed a strange sound in my vette. In first gear and moderate throttle usage, I hear a "rambeling" noise wich I think is comming from the rear of the car. It occures at aboute 3-4mph and lasts until 12-14mph. Then it seams to dissapare. Is sounds like stones in a box or something. Is this normal? If so what is it?
I don't know if it's my imagination, but I also think it is more pronaunced when turning tightly, like in a parkin lot.
Also my airbag light sometimes stays on for 1-2 min after starting. What could be the problem?
Can anybody help me here?
Thanks in advance!
Old Aug 27, 2004 | 09:33 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
this is not normal could be the posi clutches in the rear end . could be an easy fix as changing the posi fluid in the rear end ??
Old Aug 27, 2004 | 10:41 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Originally Posted by Sleepy1981
Hi!
Thanks in advance!
Your gear noise is 100% completely normal. It's due to the cut of the gears in the trans. I too was concerned when I first purchased my car, but the owner's video specifically addresses this. Unless you are familiar with the above; then it's possible you clutch packs are "skipping", and could indicate the need to change the fluid / diff. additives. But the key is if you are hearing the noise in a straight line, it's most likely the gear design.
I have no idea about you air bag light.
Old Aug 28, 2004 | 02:02 PM
ndC4spd's Avatar
ndC4spd
just a guess...but this may be the dreaded "exhaust jingle"...do a search..as there is a lot of info on this topic...
Old Nov 11, 2025 | 08:14 PM
boomestud's Avatar
boomestud
1st Gear
Default 2000 Corvette steering locks up. Bypass?
Hello! New to forum and have problem with my steering column locking up. I understand that there is a bypass. Suggestions?
In addition, I need original weather strip for passenger window. Replacement allows leak from top of window. Strip has now lip. Suggestions?
Also, how the heck do you just post instead of reply?
Boomerstud
Old Nov 11, 2025 | 09:01 PM
mmartinez's Avatar
mmartinez
LMC5 is the steering column lock bypass kit, at the very top of this forum is the post new thread option.
To 2000 Corvette problems...
