Advice on shock upgrade needed
Old Aug 31, 2004 | 02:38 PM
frank dupuy's Avatar
frank dupuy
Default Advice on shock upgrade needed
I have an 04 C5 with stock suspension. What shock can I install to stiffen up my suspension or do I need to go with Z06 springs? I need to do something to keep my new vert from bottoming out on the rough roads where I live. Some advice needed.
Old Aug 31, 2004 | 02:46 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Bilstien Sports or check out Vette Brakes offerings of the same called xtreme. Coilovers could be used also. Vette Brakes makes springs also in any rates you want.
Old Aug 31, 2004 | 06:24 PM
frank dupuy
Default Coilovers
What are coilovers and what function do they perform?
Old Sep 2, 2004 | 11:59 PM
jl240z's Avatar
jl240z
My '00 FRC had the z-51 Suspension package. I changed to Z06 shocks and it firmed it up a lot. Some of that will likely go away when I switch to non runflats in the future. The ride is a lot firmer but I have always liked that as I like to feel whats going on with the suspension. I have heard that the bilstiens are even stiffer based on past postings. You could probably search the archives and get a lot of info. Good luck
Old Sep 3, 2004 | 01:18 AM
chevyc5ls1's Avatar
chevyc5ls1
For my C5/99 coupé I got with the Z06 schock absorbers+Z06 sway bars kit+Pirelli Pzero Giallo Tyres(not run flat): stiffer car and better drivebility..
ciao
Old Sep 3, 2004 | 01:40 AM
frank dupuy
I have the ZO6 sway bar on order. I am now trying to decide on shock, 04 ZO6 or Bilstein Sport. It sounds like these two mods will give me the stiffer ride I am looking for without the expense of upgrading the springs.
Old Sep 3, 2004 | 06:24 AM
CAPN17's Avatar
CAPN17
First try a set of 04 Z06 shocks, if that does not bring the ride to where you want it, move on to springs and other items. Going radical, like coil overs is foolish until you figure out where you are going and how stiff you want the suspension to be. Slow and easy one step at a time and you will be happier and have more money for other MODs.
Old Sep 3, 2004 | 12:37 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Springs?
I originally put T1 bars and the stiffer Bilstiens (there are mild and stiffer-2 models) and really liked the way my car handled-even though I had the "soft springs" in the F45 option.
I ended up changing to ZO6 springs 'cause the weight of the blower lowered my front end excessively. The car handles great but is probably stiffer than most would like.
Roy
Old Sep 3, 2004 | 02:27 PM
VetteDrmr's Avatar
VetteDrmr
I'd go with either the '04 Z06 shocks or the Bilstein Sport shocks, whichever is cheaper. I'd leave the springs alone for now.
HTH, andh have a good one,
Mike
Old Sep 3, 2004 | 03:31 PM
Paras's Avatar
Paras
Default coilovers
I got the Doug Rippie Motorsports coil overs--a very good choice--just get the right spring rate and proper shocks. The results make the car feel completely different.
Old Sep 3, 2004 | 07:15 PM
MikeJamesC5's Avatar
MikeJamesC5
I have the Bilstein and I like them.
Old Sep 3, 2004 | 08:09 PM
frank dupuy
It sounds like Bilstein Sport or the 04 Z06 shock are very close in performance parameters. I will not be lowering car so I don't need to consider that in my choice. I will be installing the Z06 sway bars but it sounds like that will not have any bearing on my choice of shocks. It also sounds like they are equal in stiffness. So do I flip a coin ZO6 heads Bilstein tails?
To Advice on shock upgrade needed
