CLB Power unit "other uses"
Old Sep 3, 2004 | 10:18 AM
2Grumpy's Avatar
2Grumpy
Default CLB Power unit "other uses"
Can I use the electric power unit that comes with CLB kits to hold computer memory settings when I disconnect my battery? I know that you can buy these 9V units that plug into the cigarette lighter to hold the memories when disconnecting the battery, so I wondered if the kit power unit does the same thing.
Old Sep 3, 2004 | 11:10 AM
C6~Missle's Avatar
C6~Missle
Yes.. you can keep the ECM memory, radio, etc.. alive with connecting a power source via the lighter socket cable. I picked up a 12v alarm backup battery from parts direct for $4. Works great.
mike
Old Sep 3, 2004 | 03:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The power cord for the CLB plugs into the lighter OR the AUX 12 VDC socket in the glove box. It does not have a 12 VDC supply. It uses the 12 volts from the socket to power the CL motor.
I guess if you wired a 12 volt or 9 volt battery to the CLB power cord it would function as a 12 or 9 volt source.
BC
Old Sep 3, 2004 | 03:43 PM
2Grumpy's Avatar
2Grumpy
OK, makes sense to me. I'll find a power source and put it together once I've made the CLB modification.
Thanks for the replies,
To CLB Power unit "other uses"
