The front of my 99 has gotten lower recently,to the point that the front spoiler rubs on even small bumps.The spoiler is about 1 inch off the ground.I want to bring the front up...but how do I adjust this?Do you think the spring is bad.
I checked the spring,it seems to have a arc in it.How thick are the bushings under the spring?Mine are not very thick.Is there a bushing on top of the spring?Do they sell the bushings?And if the bushings are worn would that lower the car?
Sounds like your car has been lowered before by cutting the front bushings. There is no bushing on top. The bad news is you can't buy them seperate from the spring. The good news is, you don't need to to raise the car back up. Just perform the lowering process in reverse has as already been suggested. I just did this to my 99 when my daughter bought it. It was too low for her as I had cut the bushings. I just screwed the bolt back down halfway and she's happy the car riding 3/4 of an inch higher.
