proper air / fuel mixture?
Old Sep 11, 2004 | 03:23 AM
dkdonkim's Avatar
dkdonkim
Default proper air / fuel mixture?
as title says, what is proper air / fuel mixture for c5? i have predator on the way, and like to play with it some, not messiing my vert..my mods are....
blackwing, kooks header w/ cats, stinger, & removed mesh grill maf..
since c5s are not lean burn engines, i assume it should be more than 12:1????? comments will be helpful..
thanks..
happy motoring
Old Sep 11, 2004 | 06:17 AM
Patman's Avatar
Patman
When I had mine dyno tuned, the tuner was aiming for 13.0 to 1 (and he succeeded)
Old Sep 11, 2004 | 08:30 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I didn't think you could adjust your A/F ratio with a predator, I thought that was only possible with LS-1 edit or HP tuner
Old Sep 11, 2004 | 10:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT
Old Sep 11, 2004 | 11:17 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
- on a dyno, 13.0 to 1 is desired. Under load, you want it a bit richer. So... if you are going to use the real-time diags in the Predator, shoot for 12.7 or 12.8 to 1.
Old Sep 11, 2004 | 11:36 AM
Dr. Dan's Avatar
Dr. Dan
Had to pull out my Dyno sheet for this one...
Got mine to 11.9 where it flattens out at 4400RPM. Seems to start working down to this point at 3300RPM from almost 15. Could there be a problem with this set up? Car pulls strong with the I/C Mag
Old Sep 11, 2004 | 11:43 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Thats the way it should look, you don't want a steady A/F ratio across the board otherwise you'll be pig rich on one end and extremely lean on the other instead your A/F ratio will change with load and RPM
Old Sep 11, 2004 | 12:01 PM
dkdonkim's Avatar
dkdonkim
you maybe correct..i will probably richen my c5 a bit, say 2% to 3%..i know my mixture now is right around 12 by ls1 edit graph..but never did ls1 tuning..just downloaded her stat..
Old Sep 11, 2004 | 12:04 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
No - for an SC engine, I'm sure that is normal.
Old Sep 11, 2004 | 12:18 PM
BlackMagicC5's Avatar
BlackMagicC5
I heard that 12.7:1 was the optimal air/fuel ratio, but I don't know if thats true.
To proper air / fuel mixture?
