Does anyone know the correct offset for wheels?
Old Sep 19, 2004 | 12:43 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default Does anyone know the correct offset for wheels?
need to know if +20 mm offset will work properly for c-5 a.s.a.p.
thanks guys for your help!!
Old Sep 19, 2004 | 02:37 PM
flynbya2's Avatar
flynbya2
really need to know quickly.. please help!! ttt
Old Sep 19, 2004 | 04:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If the wheel is 7" wide, yeah.
What are the widths of the wheels? No one could give you a definitive answer without knowing that. But, to probably answer your question, the answer is no.
If the wheels are of a normal Vette-sized width, the wheels will probably stick out of the fenders considerably. The stock Z06 wheels are 54mm offset (9.5") front, 58mm (10.5") rear.
The less offset you run on any given wheel width, the more the wheel will stick out. If you run a narrower wheel, you can get away with less offset, but 20 is very low, and would have to be a very narrow wheel to not stick out.
To Does anyone know the correct offset for wheels?
