Gears or Headers?
Old Sep 19, 2004 | 10:01 PM
CaptainCrunch's Avatar
CaptainCrunch
Default Gears or Headers?
Hey everyone,
I've got a good amount of money that I set aside to spend on my 2001 C5 M6 vette (about $2000) that currently has a blackwing and borla stingers, and I've narrowed the choice down to either changing the rear end ratio to 4.10 or adding a set of long tube headers + dyno tune...I can do one or the other, but not both, since this is the last money that I'm going to be able to spend on my car until I graduate in three years...So of course I really want to make this money count...I spend most of my time playing with the car on the street and also dabble a bit at the local 1/8 mile track, but nothing too serious or anything...So which do you guys think would offer me the largest performance increase, in terms of both SOTP feel, launch from a dead stop, and launch from a roll?
Old Sep 19, 2004 | 10:07 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Gears will give a larger gain at the track.
Old Sep 19, 2004 | 10:32 PM
Mike Mercury's Avatar
Mike Mercury
gears give a boost at all speeds and RPM.
Old Sep 19, 2004 | 11:24 PM
abailey269's Avatar
abailey269
Not trying to hi-jack your thread but i figure you might want to know the answer to this question too:
Which gears (brand) do you guys recommend? The reason i ask is that a lot of the F-Body guys (read "about 50%) seem to have horrid problems with them whining. Does the C5 have the same issues or is it a totally different rear end?
Old Sep 19, 2004 | 11:55 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Totally different differential setup than the F-body. Very few choices of manufacturers for the C5...
I had 3.73 Motive Gears in my 01 SS and they were silent.
BTW.. Gears will be a big SOTP feel with quicker acceleration, but no actual HP power increase.. Headers will change the sound of the car and give you a power increase. SOTP feel may not be as much as gears.. (although it depends on the gear ratio you choose) Don't go for anything less than 3.73's if you are going to do it.
My vote is for 4.11's but 3.90's are a good medium...
Steve
Old Sep 20, 2004 | 01:43 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
4.10 is a lot for a every day driver... go with headers
Old Sep 20, 2004 | 08:07 AM
GOOSE JR.'s Avatar
GOOSE JR.
If you have to choose, go with the gears. The 410 would be my choice, you'll get that sotp feel with both mods but gears are the best bang for your buck.
Old Sep 20, 2004 | 08:21 AM
ROJO99's Avatar
ROJO99
What are the "Log Term" goals for your car? Do you like to race, drag or auto X? These questions are very important. If you are going to do nothing else with the car I.E. H/C, blower, NOS etc I would go with the gears and in the 4:10 ratio for a MN6. If you plan on other performance mods to the engine headers are a key element in maximizing performance.
Old Sep 20, 2004 | 01:04 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
With gears you will feel the difference immediatley. Headers will up your hp but not to a point that you would feel the difference as with the gears.
Old Sep 20, 2004 | 02:11 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Gears Gears Gears! DTE does a great job as well.
Old Sep 20, 2004 | 02:17 PM
MC TORCH RED's Avatar
MC TORCH RED
gears...
Old Sep 20, 2004 | 03:24 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I think I posted a response to this over in C5 general.. I would go with headers.. unless you plan on a tire/rim upgrade,,,if you go with 410's on stock runflats all youre going to gain is a big smoke show I would go with a tune also to take full advantage of your existing mods and the headers...
if you get better tires, bigger rims, then I would go with the gears.
Old Sep 20, 2004 | 03:30 PM
ROJO99's Avatar
ROJO99
Baldy has a point. I am running BFG DR's in the 275/35/18" size right now and if track prep is average I can still spin thru first after a smokey burn out. I heard that some 4:10 MN6 drivers say that they launch in 2nd at the track.
Old Sep 20, 2004 | 03:34 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
yeap , I was close to upgrading gears myself,,and then remembered that even with my stock 342 gear I can roast the runcraps through 2nd if I really get on it... I can't imagine 410's on stock runflats when I get money for tires/rims then gears will come,,but even then I am only considering 373's.
To Gears or Headers?
