Random Technology High Flow X Pipes & Codes
Old Sep 20, 2004 | 03:49 PM
vettenuts's Avatar
vettenuts
Default Random Technology High Flow X Pipes & Codes
Has anyone installed the RT X-pipes? They have been around for a while and I am wondering if people are getting a lot of O2 error codes with these pipes.
Old Sep 20, 2004 | 05:55 PM
BT-01-vette's Avatar
BT-01-vette
No codes here and they even passed the NJ emission testing
Old Sep 21, 2004 | 10:18 AM
AU N EGL's Avatar
AU N EGL
Codes?? We dont need no stickin codes.
Nope no codes here either. Just passed NC OBDII
Old Sep 21, 2004 | 11:16 AM
HITMAN99's Avatar
HITMAN99
I get PO420 and 430 codes about once a week on my '04 CE coupe. This is w/ Jet Hot headers, the RT x-pipe, and Z06 Ti catback.
Old Sep 21, 2004 | 10:18 PM
Dark-Knight's Avatar
Dark-Knight
Note info in signature below, no codes here.
Old Sep 21, 2004 | 11:30 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
See signature below. No codes!! I passed one of the toughest emissions inspections in Fairfax County, Virginia - the dyno/sniffer test!
Old Sep 21, 2004 | 11:32 PM
hightest's Avatar
hightest
I've been running them for three months now and no codes.
Old Sep 22, 2004 | 07:11 AM
vettenuts's Avatar
vettenuts
I can't figure this out, there seems to be an occasional random problem with codes. It has been stated that older cars may just have O2 sensors that are not responding as well and need replacement, but not on an 04. I have been looking into headers with the RT pipe. Any luck in resolving this?
Old Sep 22, 2004 | 11:19 AM
BHP's Avatar
BHP
Lots of folks here have installed headers and hi-flow cats. Consider doing a poll to see how many have cat efficiency codes based on year.
Old Sep 22, 2004 | 11:26 AM
RWhite's Avatar
RWhite
Never got codes with the RT Cats. Only have to pass OBDII here in DFW area.
Old Sep 22, 2004 | 11:28 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
What do those codes mean?
Old Sep 22, 2004 | 05:37 PM
BHP's Avatar
BHP
Cat low efficiency code. The rear O2 is reading too high or close to the front 02 voltage.
Old Sep 22, 2004 | 06:23 PM
Dr. Dan's Avatar
Dr. Dan
No Codes; installed almost a year ago. (after emissions though) Good to hear that they pass OBD II.
Old Sep 22, 2004 | 06:46 PM
BlueDragon's Avatar
BlueDragon
Nope, no codes, but then I gave the LG headers and 3" system with the Random Tech cats and sims in the rear 02 position! Passes in Calif! Just got back from having mine tested!
Old Sep 22, 2004 | 07:43 PM
vettenuts's Avatar
vettenuts
I would be really interested in the results of that poll.
Old Sep 22, 2004 | 08:44 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
If you are having cat codes... (aka rear O2 Sensor Codes) just throw a set of O2 Simulators on and eliminate the rear O2's (like if you weren't running cats)... You dont need the rears. Also, you could use an LS1 Edit tune and turn them off.
Hitman99 are those the only codes you are getting with the headers??? I'm looking at a set of those Jet-Hots now for my car..
Steve
Old Sep 23, 2004 | 02:10 AM
Dirty Howie's Avatar
Dirty Howie
I have th KOOKs setup with highflows and xpipe.
I get the P0420 every 3-400 miles.
To Random Technology High Flow X Pipes & Codes
Old Sep 23, 2004 | 09:10 AM
HITMAN99's Avatar
HITMAN99
Steve
Yes, they are the only codes I am getting. I get the PO430 a bit more often than the PO420. I have seen at least one post suggesting that replacing the rear O2 sensors with ones for the front will help, as the fronts have a better heating element. ??? That doesn't make a whole lot of sense to me. I have also heard that replacing the rears with a non-OEM sensor might help --- again, that doesn't make a lot of sense.
One thought I had was to replace the fronts, as they might have a little oil on them. The car was burning over a full quart per 5K miles, but I have since added a catch can. My thought was that if the fronts had some oil residue on them, they might not register as much voltage, thereby making them read closer to what the rears read.
So far, I am just resetting the codes once a week. I have already had the car tuned w/ HP Tuners, and can get the codes deleted free of charge. However, I'm a little concerned that the OBDII emissions scan (down the road a few years) will be able to detect the deletion.
Gary
Old Sep 23, 2004 | 01:45 PM
TopCat's Avatar
TopCat
Hitman99-
I'm looking at a set of those Jet-Hots now for my car. Did you install yourself? How do you like them (sound/power)? Get dyno results when you got your tune?
Thanks for any info
- TC
Old Sep 23, 2004 | 02:01 PM
HITMAN99's Avatar
HITMAN99
They were professionally installed at F-Body Central in Baltimore, but the install was very easy --- no jacking of the engine required, or any special measures.
I dynoed afterwards at 324 HP, 339 TQ, w/o the benefit of wide-band tuning, as the dyno shop's tailpipe sniffer was on the fritz. The engine is still running fairly lean, w/ some pinging at cruise under light acceleration. My guess is that I'm getting some knock retard above 4400 RPMs, which is keeping the HP number down. In my experience, HP and TQ numbers are usually around the same for LS1's w/ OEM cams.
I am very happy with the Jet Hots --- appearance, sound, and performance.
Gary
