Best I can figure it, I've got air in the ABS system. With the help of a friend, I bleed the brake again using the manual method described in the manual. Push the brake pedal down once and hold. Open the bleeder screw and let fluid (and air) out. Close bleeder screw. Release brakes. After going around the car twice, the brake pedal is still spongy. This is why I believe there is air in the ABS system.
Does anyone have a Tech II tool in central CT they would let me borrow? Or could someone recommend a good dealer/mechanic?
Also, I've look all over the manuals but I can't find a description for the other reservoir near main reservoir sitting on top of master cylinder. Is this for the ABS system? How do you flush out the fluid from this reservoir?
The other reservoir (round top) is the clutch hydraulics.
When you're bleeding the brakes, do you get any air, or is it all fluid? Is the fluid clean?
You can get air into the ABS system if you bleed the brakes out enough so that the reservior goes dry. Did this happen?
Dumb question: you did remove the reservior lid during the bleeding process, correct?
When I first started, I used a turkey baster to remove as much old fluid as I could. I could have gotten the reservoir empty. As a result I believe some air got into the system when initially bleeding.
My buddy and I manually bleed the brakes with the reservoir lid in place. Is this not correct?
id have to look closer but did you get both sides of the calipers? chances are you did not get any air in with what you did, basting.
as long as you didnt pump the pedal when it was mt ish.
and use a lot of leg when bleeding, your trying to "pump" the air out.
don
You don't mention what year your car is but there are 2 different bleed sequences. 97 through 2000 is RR LR RF LF. 2001 and later is RR LF LR RF.
Also, I find it is, almost, impossible to get the pumping and opening and closing of the bleeder valve really co ordinated. You actually want to be closing the valve when the brake is still moving towards the end of the stroke. One of the things you can do to make this less critical is make sure the bleeder hose is always in a couple on inches of brake fluid at the bottom of your catch bottle. This will make sure you are not sucking air back in. I doubt if your ABS has air as you really have to have the resovoir empty and then have several brake strokes.
Start at the wheel closest to the master cylinder, then the next closest etc... Stay at each wheel until the fluid does not have any more air, then move on. So you will have to pump and hold a whole bunch. Eventually you will get some pedal, then brakes.
Don't you mean start at the wheel futherest away?
And that was only true of cars from 97 through 2000.
From 2001 and on C5s have electronic proportioning and the sequence is diagonal. RR LF LR RF.
It's a '99, so I've using the following sequence: RR, LR, RF, LF.
Initially when I started this whole mess, I used the turkey baster to remove the old fluid. I then attached a power bleeder and pumped up the system to verify I had no leaks. This is when I think I pumped air into the ABS. I'm no professional, so I'm guessing here.
I'll say. The mystery is solved. Never leave the reservoir empty when you start putting pressure in the system.
No, start at the one closest to the master cylinder. If you start at the one furthest away you are going to be there for a long time.
From the 2000 C5 service manual:
3.3. If it is necessary to bleed all of the brake calipers, the following sequence should be used:
3.3.1. Right rear
3.3.2. Left rear
3.3.3. Right front
3.3.4. Left front
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
3.3.1. Right rear
3.3.2. Left rear
3.3.3. Right front
3.3.4. Left front
I beleive he is referrring to the bleeding sequence if you're trying to flush the ABS....
