Cartek Fall Specials
Old Sep 21, 2004 | 12:07 AM
Dave_Busch's Avatar
Dave_Busch
Default Cartek Fall Specials
We are offering the following specials good until October 31st.
C5 gears. Your choice of 3.42, 3.73, 3.90 and 4.10. This price includes: gears, hot tank case, deburr case, clean and inspect all parts, replace all worn bearings and clutches, set back lash and pinion depth and reassemble.
$895 exchange or $1,095 installed. We can also install a heavy duty out put shaft for an additional $350.
Prices are with a core exchange. Gears can only be installed in a 3.15 or numerically higher gear ratio. We can supply a rear, call for pricing.
C5 headers on sale.
Kooks 1 ¾” and 1 7/8” stainless steel headers installed for $1,575 off road or $1,825 with high flow cats.
TPIS ceramic coated 1 ¾” headers installed $1,275.
For self installations, call or email for parts and shipping prices.
Heads and cam special.
All heads and cam packages below include: base line dyno runs, Cartek ported heads, Cartek custom ground cam, head gaskets, other gaskets, seals, bolts, Dexcool coolant, oil, oil filter, NGK plugs, custom programming, after dyno runs, all parts and labor.
Cartek Stage 2 heads includes, full intake, exhaust, chamber porting and polishing, stainless 2.02 intake and 1.57 exhaust valves, titanium retainers, springs, viton valve seals, Serdi contoured valve job, CBN milled .030, hot tanked, flowed, cleaned and assembled. Choice of cams. $4,999.
Cartek Stage 2X heads include, full intake, exhaust, chamber porting and polishing, stainless 2.02 intake and 1.57 exhaust valves, titanium retainers, springs, viton valve seals, Serdi contoured valve job, CBN milled .030, hot tanked, flowed, cleaned and assembled. Choice of cams and upgraded head gaskets. $5,599.
Cartek Stage 3X heads include, full intake, exhaust, chamber porting and polishing, stainless 2.02 intake and 1.57 exhaust valves, titanium retainers, springs, viton valve seals, Serdi contoured valve job, CBN milled .030, hot tanked, flowed, cleaned and assembled. Choice of cams and upgraded head gaskets. $5,999.
All prices are with a core exchange. You can upgrade to ZO6 heads on non ZO6 cars for an additional cost.
I can be reached Monday thru Friday 9AM to 6PM EST at 908-317-4496 or davebusch@cartek.net
Old Sep 21, 2004 | 12:20 AM
jfrc's Avatar
jfrc
C5 gears.....4.10. This price includes: gears, hot tank case, deburr case, clean and inspect all parts, replace all worn bearings and clutches, set back lash and pinion depth and reassemble.
[/email]
I take it you have more gears in stock now! Contact me when you are ready, because I am still ready from last inquiry.
Jason
Old Sep 21, 2004 | 09:35 AM
Dave_Busch's Avatar
Dave_Busch
Jason
Yes we do have more gears in stock. Your rear is going to be the next one built.
Old Sep 21, 2004 | 10:36 PM
CraZee ZO6's Avatar
CraZee ZO6
PLUS TUNE? OR TUNED?
Old Oct 4, 2004 | 10:07 AM
Dave_Busch's Avatar
Dave_Busch
This is with out dyno tuning.
Old Oct 4, 2004 | 10:50 AM
add's Avatar
add
What gears do you recomend with an A4 daily driver? Currently have 3.15's and would like to do some track events?
Tony
Old Oct 4, 2004 | 10:27 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
ttt for ya Dave
Old Oct 5, 2004 | 05:07 PM
Dave_Busch's Avatar
Dave_Busch
Tony
We normally install 3.42 gears on street only cars and 3.73 gears on cars that spend some time drag racing and on the street. The 3.73 gears will increase your cruising Rpm’s. I recommend talking with people that have them and get their opinion.
Old Oct 6, 2004 | 10:02 PM
NJVetteGuy's Avatar
NJVetteGuy
Those are some great prices on heads/cam! With regards to 3.42 vs. 3.73, I have had both and the 3.73s are great. I had 2.73s in my car originally, both sets of gears aren't bad on the highway so don't be afraid to go 3.73, especially if you do a lot of city driving. If I knew how much of a difference the gear swap made when I bought the car, I would have swapped them the day I took my C5 home.
Old Oct 7, 2004 | 02:32 AM
jfrc's Avatar
jfrc
I cannot wait
Old Oct 7, 2004 | 02:40 PM
Dave_Busch's Avatar
Dave_Busch
I cannot wait
Its leaving here tomorow.
Old Oct 7, 2004 | 06:14 PM
STEALTH 99 C5's Avatar
STEALTH 99 C5
Dave , Don't forget , I need that 3-series carrier for Dennis K.
Old Oct 7, 2004 | 10:37 PM
jfrc's Avatar
jfrc
it has been awhile since my first request, so please email or PM me if you need any info. thanks again
jason
Old Oct 18, 2004 | 11:22 AM
Dave_Busch's Avatar
Dave_Busch
No problem mike.
Old Oct 18, 2004 | 03:52 PM
Wide Open Throttle's Avatar
Wide Open Throttle
Good deal. TTT for ya.
Old Oct 18, 2004 | 06:14 PM
99SlowC5's Avatar
99SlowC5
Dave,
I sent you a PM
JEFF SMITH
Old Oct 19, 2004 | 10:55 AM
95jersey's Avatar
95jersey
C5 headers on sale.
Dave,
How much for a simple LS1/6 edit dyno/tune?
To Cartek Fall Specials
Old Oct 20, 2004 | 01:46 AM
NJVetteGuy's Avatar
NJVetteGuy
Originally Posted by 95jersey
Dave,
I think your best bet would be to call him at the shop, (908)317-4496. I stopped by there yesterday and don't even know how Dave has time to go online with all the work down there
Old Oct 21, 2004 | 10:19 AM
Red5's Avatar
Red5
I have the stage II on my 98 C5 and they are GREAT!
Old Oct 21, 2004 | 07:54 PM
BigMike NY's Avatar
BigMike NY
Excellent prices on the heads/cam packages!! Now I need another car to put it on, LOL!
