I cannot say Thank You enough to FRC Tom...he met with me tonight and in under an hour got my car running better than it has in a long long time. I have been for 2 months now with erratic idle issues, stalling etc. After I left his house tonight I was
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Any info on what was done to correct the problem ?
I brought the idle up from 750 to 925 rpms to start.
I then adjusted the idle airflow vs. ect and TPS vs IAT.
The fans were still set stock so I adjusted them to come on at 186 to take advantage of the 172 stat. His IAT is still high (140+) because of the blackwing taking in the hot air under the hood.
We then took a cruise and I scanned and then adjusted the LTFTs down to about -1.80 vs the +4-7 it was running.
Brought the spark table up 2 points at 400-600-800-1000 rpms from 0.08g/cyl through 0.32g/cyl and then smoothed out the rest of the spark table.
In other words he did a Computer Tune on the car with either LS1Edit or HPTuner. Probably HP Tuner based on the scan.
ECT (Engine Collat Temp)
LTFT (Long Term Fuel Trim Cells) Positve #'s are Lean and negative #'s are rich. He richened it up a bit to get all negative LTFT's.
IAT (Intake Air Temp)
TPS (Throttle Position Sensor)
The timing table is dimensioned by g/cyl (grams of dynamic airflow in the cylinder?) and rpm. He advanced the timing in the lower RPM ranges a little.
HPTuner allows you to drive around and log various sensor data from the PCM. This info can then be analyzed to determine corrections that may need to be made.
How did you bring the LTFTs down? IFR table? MAF table? Ve?
Did you make any VE adjustments
