FOB problem
Old Oct 3, 2004 | 08:41 AM
YO-EL's Avatar
YO-EL
Guys...
Let me try to clear this.....
NEW FOB, you do "re-learn or re-train" via the DIC....
Change battery you do the "re-sync".... it even says inside the FOB, "replace battery, do re-sync"... (Just hold down the lock & unlock until horn beeps...)
Old Oct 3, 2004 | 10:35 AM
DDSLT5's Avatar
DDSLT5
Originally Posted by YO-EL
Guys...
Yeah - provided the fob is for you model year vette - mine doesn't work on 00 and earlier!
Old Oct 3, 2004 | 10:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you change the car battery you will need to relearn all of the FOBs! You can re-sync all day and it wont respond!
Thats why many of us have FOB issues. When your car sits for an extended period of time and the battery looses a lot of it's charge OR when you have an OLD car battery, a lot of C5 owners keep loosing sync or their fobs quit working for no apparent reason. The Trensmitter/Receiver resets it self if sees less than 9 VDC. Been there, done that!
BC
Old Oct 3, 2004 | 12:32 PM
jeff1surfs's Avatar
jeff1surfs
Originally Posted by Bill Curlee
Jeff
Roll the windows down, lock the doors using the lock button on the inside of the door and shut the door. The system will arm it self. Reach in and open the door using the door opening latch on the inside. If the alarm is working properly it should alarm. Try this on the passengers door also. To secure the alarm, you will need to insert the key in the ignition and turn the switch to on.
Shut the doors and lock the door with the key in the door key lock. Try to open the door from the inside again. It should alarm.
Arm the alarm again and reach in and pop the rear hatch using the switch on the dash. Alarm should sound.
Please let us know how you make out.
BC
Thanks Bill,
I will try it today, am at work now.
I'll post the results when I am done.
Old Oct 3, 2004 | 12:34 PM
jeff1surfs's Avatar
jeff1surfs
Originally Posted by Z QQH 6
If anyone is looking for a key fob go to Ebay look for 1XPJDD or emailXPNitro@aol.com He deals in fobs. I bought a set for my 01Z as back ups in case. It was only $25.00 mailed. #1 gently used and #2 is brand new.
Tough ride
