handheld tuners
Old Sep 26, 2004 | 09:37 PM
hightest's Avatar
hightest
Default handheld tuners
I'm looking for a handheld tuner. I don't want to go with a predator, as my gear change has already been edited with LS1 and I don't want the hassle of getting a factory tune back in my car.
I don't plan on any major mods down the road, just enough tuning capability for A/F ratios, line pressure adjustments, and timing.
Have any of you out there come across a decent programmer that might fit the bill?
Thanks.
Old Sep 26, 2004 | 09:59 PM
LS1LT1's Avatar
LS1LT1
There's a chance that you won't even be able to use a handheld if you already have some LS1 Edit tuning in there, I asked something similar over on LS1 Tech once and the general response was no, can't use a Hypertech/Predator etc on a car that's had changes made via Edit even if they are not related (ie: say you had cooling fans set with Edit but not shift points, the handhelds might no longer be able to change shift points either).
But they could be wrong.
LS1 Edit is still best probably.
Also, almost any handheld out there will still have the ability to change/correct for the gear change so avoiding a Predator simply for that reason is unnecessary.
I would get the Predator over the Hypertech but the DiVinci and Crane (same thing?) units look like they could be decent as well but again, you might have to put your stock tune back in first.
Old Sep 27, 2004 | 12:45 AM
LS1LT1's Avatar
LS1LT1
LS1 Edit (or the newer HP Tuners) is still best in most applications.
I would get the Predator over the Hypertech but the Vinci and Crane (same thing?) units look like they could be decent as well but again, you might have to put your stock tune back in first.
Old Sep 27, 2004 | 12:49 AM
LS1LT1's Avatar
LS1LT1
Old Sep 27, 2004 | 01:00 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
you'll have to go back to stock tune. due to editing programs locking tables and data, it may not read all the files. then trying to upload, it might miss some files. in some cases, the handheld might not even be able to read the PCM at all due to the edit. i use the VHP tuner and have discussed it with them.
Old Sep 27, 2004 | 02:19 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
To handheld tuners
