K&N Filter...
Old Sep 28, 2004 | 07:04 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default K&N Filter...
Posted this in response to a post in general... probably more appropriate in Tech.
Does anyone know which of these filters is the correct size for mounting to the stock MAF?
RC-5040 Product Specifications
Product Style: Oval Tapered Universal Air Filter
Base Outside Length: 8.5 in (216 mm)
Base Outside Width: 5.25 in (133 mm)
Flange Inside Diameter: 3.5 in (89 mm)
Flange Length: 0.75 in (19 mm)
Flange Type: Centered
Height: 5.5 in (140 mm)
Top Outside Length: 6.25 in (159 mm)
Top Outside Width: 4 in (102 mm)
Top Style: Metal
Top Material/Finish: Chrome
Filter Re-Oiling Amount: 1.32 oz (39 ml)
Flanges: 1
Weight: 2.1 lb (1 kg)
Product Box Length: 8.13 in (206 mm)
Product Box Width: 8.13 in (206 mm)
Product Box Height: 8.25 in (210 mm)
RF-1040 Product Specifications
Base Outside Length: 9 in (229 mm)
Base Outside Width: 5.75 in (146 mm)
Flange Inside Diameter: 4 in (102 mm)
Height: 7.5 in (191 mm)
Top Outside Length: 7 in (178 mm)
Top Outside Width: 4.5 in (114 mm)
Top Style: Metal
Top Material/Finish: Stainless Steel
Filter Re-Oiling Amount: 2.6 oz (77 ml)
Weight: 2 lb (0.9 kg)
Product Box Length: 9 in (229 mm)
Product Box Width: 9 in (229 mm)
Product Box Height: 9 in (229 mm)
Old Sep 29, 2004 | 09:41 AM
golfer's Avatar
golfer
I have a 2000 vert and the MAF sensor has a 3.5" OD. So, I would say that your 99 would be the same. In other words the RC-5040 would be the correct filter.
Old Sep 29, 2004 | 10:37 AM
zeusoftexas's Avatar
zeusoftexas
I used a 1040 on my 97, but I did have to make a shim out of a 3.5" hose. Had it on for about 3000 miles with no problems. you will need to cut a hole for the vent tube. Looks really good when you are done. Make sure your hood seal is in good order, if not water will leak down on the filter.
To K&N Filter...
