1998 C5 Won't Start
Old Oct 14, 2004 | 11:06 PM
Jharms's Avatar
Jharms
I'm fixed! Thanks to the Corvette Forum. One of the recommendations was to try to disable the alarm with the keyfob. That was the tick!! My wife drive me back to my Corvette and the proximity didn't open the doors (great feature, by the way) so I pushed the unlock button on the keyfob. When I go in it started right up! I can't believe I didn't try this trick before I was given a ride home.
Thanks for all the help!!!!!
Old Oct 14, 2004 | 11:40 PM
cweed's Avatar
cweed
glad you got it going and it was a small thing... good you were able to leave your car at your job without having to get it towed, would have been kinda bad if you parked somewhere on the street ending up in towing the car for nothing hehe
Old Oct 15, 2004 | 06:45 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Thats a good idea for all of us to remember. Glad you got it started!
Jeff
Old Oct 15, 2004 | 07:26 AM
Jharms's Avatar
Jharms
Originally Posted by devo
This happened to mine.
Here is what I did.
get in the car use your keyfob and arm the security system.
unarm it then stick the key in and see if it starts.
Mine did the exact same thing all lights worked but no sound no nothing when I turned the key to start. my alarm was active and I didnt know it.
Good luck
One last note from me on this subject.
I want to send a big THANK YOU to devo. He saved me from a tow and probably big diagnostic expense for something so simple.
Hats off to you devo!
Old Oct 15, 2004 | 08:54 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
You are very welcome!
When this happened to me it I could not figure it out, But I knew it wasnt the battery.
so by accident my keyfob armed while i was in the car and bingo i knew that was it!
I had a feeling that was the same issue you were having.
It's so easy to overlook something so simple.
Glad all is well, that will cost you one (1) sixpack!
Old Oct 15, 2004 | 08:11 PM
DRR's Avatar
DRR
Good job Devo. One to remember in case it ever happens to me. Doug
Old Oct 15, 2004 | 11:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jharms
I had a 98 coupe MN6. A few weeks out of warrenty my car did the same thing! I would turn the key 5-6 times and it would finially start. One day it stranded me (luckily I was home) and would not start!
There are two things that could also be giving you problems and I recommend that you take a look at them.
The first is the Theft Deterrant Relay. The BCM get inputs from the key security system (pellet in the key), The vehicle security system, and a few other things. Once the BCM has all of the proper inputs, it allows power to the Theft Deterrant relay which energizes and allows power to go to the starter.
The other componet in this circuit is the netural safety switch (on an automatic) OR clutch safety switch (on a manual vehicle)
My Theft deterrant relay had water in it from condenstaion from the AC system.
The Theft Deterrant Relay is located in the passengers foot well behind the toe board. You have to remove the toe board, them remove the carpeted knee bolster on the bottom of the dash. The relay is on the fire wall jst above the silver box (BCM)
I removed the plastic cover from the relay and found the relay componets inside was trashed!!!
If you need additional assistance i can dig DEEPER!!
Bill C
Old Oct 16, 2004 | 01:07 AM
JonnyB's Avatar
JonnyB
Originally Posted by Bill Curlee
Jharms
Bill C
Excellent info to remember for future reference - hope I never have to remember it.
I see you are in CTtoo, I am in Stamford - any competent mechanics up/out your way? Only knucklehead stealers around here. I acutally went to one stealership where the vette mechanic appeared to be scared of the car - I told them I would think about the oil change and get back to them - then I ran like hell and never looked back.
Old Oct 16, 2004 | 08:34 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
JonnyB
I have had VERY good luck with M J Sullivan Chevy in New London CT.
I have had some minor warrenty work accomplished with them and they have been very compenent.
On the OTHER HAND I allowed one dealer in the area to accomplish some warrenty work and they broke more stuff than they fixed!
I WONT be going back there again!
Bill Curlee
Old Oct 18, 2004 | 05:46 PM
SNAKEKILLER!'s Avatar
SNAKEKILLER!
Default Problem fixed......
It could be you're ignition relay...I had the same happen to my car....You would get some type of dimming or guage flutter if it were you're starter....The relay on the ignition chamber wears out....depending how many times you turn the car off and on throughout the years....eventually it fails...The part is $80 to $150.00.....I cant remember exactly, but it's an easy fix...
