About 3 weeks ago I changed plugs on my dead stock '00 FRC from the originals to NGK TR55s. The original plugs were each gapped at 0.057" and the TR55s were gapped the same right out of the box, so I left them there. As I've been driving, I've noticed that the idle is lower (around 700 rpm) and hunts and wanders, whereas before it was rocksteady at 800. Also, at steady throttle openings, there is an annoying surge that wasn't there before. I've checked for codes, there are none. I did a couple of dyno pulls and, other than the AFR dropping into the 11.9-12.1 range, there was no indication of a problem. But the engine didn't do this before. I checked to see if there were any hoses off the TB/MAF/air filter: Nope.
I'm thinking that the gap is the problem. I think I read somewhere that Chebby changed the recommended plug gap. So:
1) anyone else have problems running TR55s @ 0.057"?
2) is there a newer, different gap from the 0.057" that left the factory on '00s?
I checked the archives, but most folks had mods, so...
