High Temp??
Old Oct 29, 2004 | 02:22 PM
robbber's Avatar
robbber
Default High Temp??
I am used to my temp reading right around 220 degrees. Lately, it has risen to as high as 254 degrees. Could this be a problem, and what is the range of temps if anyone knows. Thanks for the help,
Robbber
Old Oct 29, 2004 | 04:01 PM
jo8243's Avatar
jo8243
Have you changed your driving style or type of driving (driving harder or more stop-n-go)?
Is your coolant temp staying the same as before?
Old Oct 29, 2004 | 04:08 PM
pocorojo's Avatar
pocorojo
I had a problem with my 97 like that. It turned out to be a lot of small stuff clogging the airflow in the radiator. I was able to clean it out by removing the radiator and using a pressure nozzle on the garden hose to blow the stuff back out the front......jim
Old Oct 29, 2004 | 04:21 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
when I cleaned out my radiator and condensor, I got a half cup of sand, fuzzies and woolies, bugs and trash. More than likely this is your problem..
Old Oct 30, 2004 | 12:18 AM
JC in XTC5's Avatar
JC in XTC5
But these temps are high since the fans should kick in long before this (both fans are on by the time you get into the 230s). If the radiator is clean, then let the car idle and see if the fans kick in. If your still seeing temps above 230 then could be your thermostat is stuck/going bad.
Old Oct 30, 2004 | 12:53 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Get a power flush, clean and refill. get all the crap out of there.
Old Oct 30, 2004 | 04:49 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
My money is on crap in the radiator fins...
Old Oct 30, 2004 | 07:35 AM
bekdad's Avatar
bekdad
At 254 degrees, you are just 2 degrees away from getting the "coolant over temp" warning on the DIC. So, yes, this is a problem. Highest I've ever seen - sitting in 30 minutes of summer gridlock - was 226.
Old Oct 30, 2004 | 10:16 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Only two things to add here.. your rad cap may have gone bad and are you sure your fans are coming on?
VR
To High Temp??
