Tire sensor
Old Nov 3, 2004 | 12:51 AM
98 corvette's Avatar
98 corvette
Default Tire sensor
The tire sensor on my 98 said that the right front tire was low 24 lb, when I checked it it was at 35lb. I then checked the left front tire(drivers side) and it read at 24lb. Is my computer reading wrong or is the passenger side the left side and the drivers side the right side
Old Nov 3, 2004 | 02:05 AM
Pontiaker's Avatar
Pontiaker
Sounds like when they were programmed they might have been done out of sequence. Iam getting the proper steps to do this tomorrow, will come post when I have done it and know it works.
Old Nov 3, 2004 | 05:03 AM
Richin Chicago's Avatar
Richin Chicago
Resetting Tire Pressure Monitors -- 1 of 1
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the
display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in
order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool
(large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed
(if this takes more than 15 seconds, pull magnet back and try again, it will
give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the
following order as directed by the IPC messages:
-Learn R Front Tire
-Learn R Rear Tire
-Learn L Rear Tire
Programming can be canceled by turning ignition off, waiting 2 minutes with
no sensors being learned, finishing all 4 wheels or through the DIC.
If the programming is canceled with less than 4 sensors learned, it will only
accept the codes programmed up to that point.
Just to be sure, it's really easy to reset the sensors if you have a magnet:
To train the sensors you need a strong (preferably u-shaped or circular) magnet.
1. Turn key to ON (don't start the car)
2. Press the DIC RESET button to clear any warning messages, if they are present.
3. Press the OPTIONS button and cycle through the menu until the display goes blank.
4. Press and hold the RESET button until FOB training appears on the display.
5. Press the OPTIONS button once and the Tire Training message should appear.
6. Press the RESET button once, and the Learn Left Front Tire message appears.
7. Hold a magnet over the Valve Stem on left front wheel. You may have to move it around the valve stem to hit the right spot.
8. When the horn beeps (about 5 sec. later), programming is complete for THAT wheel.
9. Program the other 3 wheel sensors as directed by the DIC message display. The sequence is as follows: L Front, R Front, R Rear, L Rear.
You only have about 30 seconds, I believe, to train each tire. If the sensor isn't reset in that time, the training program shuts back down.
If your sensor isn't reading the pressure correctly, this procedure will not help. You can try letting out almost all of the air in the tire and refilling it. Sometimes that clears the sensors. If not, the sensor probably needs to be replaced.
To Tire sensor
