MAF screen... how do you remove
Old Nov 4, 2004 | 11:03 PM
whitelite's Avatar
whitelite
Default MAF screen... how do you remove
I'm thinking of removing the screen in my 2k. What's an easy way to cut it out and get a clean finished job.
Old Nov 4, 2004 | 11:08 PM
SideStep's Avatar
SideStep
Why do you want to take the screen out???
Old Nov 4, 2004 | 11:19 PM
Pilot135R's Avatar
Pilot135R
On my '02 I used a small flathead screwdriver and patiently worked my way around the screen. Take your time and it not's a hard at all.
On the flip side, I don't think it was worth it to remove the screen. Once you take it out, it's out for good.
Good luck!
Old Nov 5, 2004 | 12:21 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Don't do it....no gains and possibly probs. with surging etc....
Old Nov 5, 2004 | 12:37 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Old Nov 5, 2004 | 01:01 PM
jcbuncc's Avatar
jcbuncc
The screen is there to straighten out the air as it flows over the sensors. Leave it alone.
Old Nov 5, 2004 | 02:11 PM
THEO C5's Avatar
THEO C5
Leave the screen
Old Nov 5, 2004 | 03:03 PM
Dave68's Avatar
Dave68
Especially if you have/plan to install an aftermarket intake filter setup.
Old Nov 5, 2004 | 06:27 PM
whitelite's Avatar
whitelite
Ok, Ok, I'll leave it in......
Old Nov 5, 2004 | 06:49 PM
2KVetteMan's Avatar
2KVetteMan
Here is my experience to share with everyone. I removed the maf screen from my 2k vette.
I installed many after market parts. I have gone back to stock with everything, except the MAF, you can't put the screen back on. So I get a computer error. Guess what it is. My MAF is bad, it causes my vette to studdard upon accelaration. The cause from the computer reading "MAF" it does not know how to read the air flow.
So know I have to buy a new maf, since my is damaged. $110.00 from gmpartsdirect.com. You can only buy the ones without the screen now.
So don't do it, it was not worth it. Yes the new vettes have no screens, but they are programmed that way.
Old Nov 5, 2004 | 06:54 PM
LoneStarFRC's Avatar
LoneStarFRC
I used an Xacto knife. I have Donaldson, Z06 intake, Corsa w/x-pipe...no codes, surging or hesitation. Go figure.
Robert
Old Nov 5, 2004 | 09:56 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I am not sure what new vets don't have them. I have a 2004 and it has a screen. I think the 05's have screens also.
Old Nov 5, 2004 | 11:49 PM
Elite Engineering
Supporting Vendor
St. jude Donor '14
The screens are there for a reason. It acts as a flow conditioner and helps to take away the swirl in the air stream while creating a more uniform velocity profile. Surging can result from unconditioned or non-uniform air hitting the Mass Air Flow Sensor (MAFS).
Old Nov 6, 2004 | 08:53 AM
JTS97Z28's Avatar
JTS97Z28
I had a spare MAF housing that I descreened from my 97 Camaro Z28. Its the exact housing as my 99 vette so I decided to try it. Car runs great no codes and no surging, and I do have my original to swap back in if I want
Old Nov 6, 2004 | 10:09 AM
Joe's Eray's Avatar
Joe's Eray
I think the LS6 engines are the ones with no screens.
Old Nov 6, 2004 | 11:02 AM
bcseitz's Avatar
bcseitz
I believe only the newer Z06's were designed w/o screens.
In Oct. (last month) I went to Xtreme Motorsports to have my 03 baselined. My dealings there have been with Mike. He has been really friendly, quite knowledgeable and willing to share info. about what works and what doesn't.
He asked me what I had done to the car so far. I told him a Z06 air box lid, Fram Air Hog filter and I popped the screen out of the MAF. His first words were: YOU TOOK THE SCREEN OUT ? Ooooh NO! that might be BAD !
As it turned out after the first dyno run with my toy, the AF ratio didn't turn out to far off. I was going back next week anyway to get a couple mods done and a custom tune on the dyno. Mike thought he could work with the missing MAF screen.
If you want to take the screen out it's easy. Just poke a screwdriver through the screen and just gently start prying up in a circular mannor. The trim ring/screen will just pop out.
From my little experience... DON"T DO IT. Unless you and your tuner have a good reason to.
Old Nov 6, 2004 | 09:17 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Don't remove the screen. If you wanna try it out w/o screen, post on the for sale and you will find one cheap (just housing) and try it on to see if you like it.
The MAF with screen is really rare now since there was a long post about removing the screen and ton of people's done it to their MAF's
To MAF screen... how do you remove
