If you do a search, you'll find several threads about removing the emblems. In a nut shell - use a hair dryer to heat the area up and the emblems come off fairly easily.
Good luck.
You can also use fishing line and work it underneath the emblem to help release the adhesive after heating the area..
do not remove the front emblem there are 2 holes in the bumper cover after you take the emblem off
i was planning on yanking this one off too
if that's true, thanks in advance. i have a bunch of chips, so maybe it'll an excuse to touch up, fill in holes, and repaint the front cover
