I wouldn't.....I use the GUNK Citrus Based cleaner...does a great job and make sthe rubber / plastic look great as well...low pressure spray to rinse....
I have done this for years on all of my cars and trucks,, Neverhad a problem. just make sure you dont spray directly into alternator or ignition....I usually keep the pressure down and kind of rinse important stuff, and blast the grime on the block and other dirty areas,,,,use some judgement and you should be fine. My motors are clean all the time. I usually spray wd-40 or some protectant overt the metal and plastic, staying away from hoses and belts. I have washed others engines and had some funny things happen with wipers and things until they dried out (bosses truck) ...As I said before , dont use high pressure on electrical stuff....
yes, i usually cover electrical pars with plastic bags and tape them tight. it's just a reminder for me not to directly spray there, and keeps extra water splash from hitting it. just a precaution i have done as a habit over the yrs
I use simple green and after soaking for a few minutes, rinse off with light mist of water from garden hose. Also always cover alternator with plastic.
Never any problems and always great results with this method.
There was a post a while back that stated that if water is left standing around the knock sensor connectors (below the intake manifold) it will cause them to corrode and fail!
I recently took mine to the car wash and hosed out the engine compartment. I really wanted to remove the fuel rail covers first but I knew there could be trouble if I did that. Left them ON ! Used the soap spray first then the rinse spray. Try to go easy around the Alt. Came out great. Towel dryed everything under there then went home and gave the whole car a hand wash.
Just be careful not to seperate the layers of underhood insulation. Don't hit the insulation on the edges from an angle. Angle the wand so it points straight at the insulation.
In addition to all the good pointers above, I'll just say I've been doing it for decades and never had a problem except once. I cracked the cast iron exhaust manifold on one car. Ever since then I've been careful to make sure the motor wasn't real hot. I do a light cooldown spray first then I work on other grimy areas before I come back to work on the motor.
I use a product named Bike Bright. It is a very good cleaner and doesn't harm paint, rubber, electrical, aluiminum and leaves a special protectant on all rubber making it look new. It is made for motorcycles and engineered to be sprayed on everything (not in alt) and just hosed off with no drying need. works great.
