got codes!!!
Old Nov 9, 2004 | 05:23 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
Default got codes!!!
P1626h
U1064h
U1040h
U1088h
U1016h
U1176h
U1096h
Any Ideas...i Had A P0101 H Code On Their A Few Weeks Ago But Cleared It Which Would Have Been The Maf, And Chevy Would Have Replaced It Had I Left The Code There! But My Car Has A Lag Sometimes When Trying To Accelerate Lightly. Thanks!
Old Nov 9, 2004 | 05:30 PM
2KVetteMan's Avatar
2KVetteMan
That is what the code means. Now I don't know what causes it. Maybe someone can explain. The code U1088h I could not find anything on.
Cheers!
Originally Posted by spoiled996
P1626 Theft Deterrent System Fuel enable Circuit -C
U1064 Lose of Communications with DCM
U1040 Loss of Communication with TCS
U1088h
U1016 Loss Of Communication with PCM (No SOH Message Received -RFA
U1176 Loss of Communications with RFA
U1096 Loss of Communications with IPC (No State of Health Message)
Old Nov 9, 2004 | 06:14 PM
servohead's Avatar
servohead
wow, the only codes you are recovering are communication codes? Battery voltage ok? Alternator ok? Any recent software changes/downloads? If all of that is ok, then start checking wiring fuses and relays... I ran through that this morning at work.
Old Nov 9, 2004 | 06:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The LOSS OF COMMs codes are CLASSIC signs of a weak or bad battery! If your battery is weak because it has been sitting for a while or it is going bad, it will crank the car but the avaliable voltage will drop very low (9-10 volts) during cranking and the modules will loose comms.
My 98 did the same thing for a VERY long time before I broke down and got a new battery! After the battery change, NO MORE CODES!
You can have it checked out for free at most automotive stores Advanced AutoZone ect
Bill C
Old Nov 9, 2004 | 07:03 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
i have a new optima red top, so maybe the battery change a few months back threw it, or getting a viper alarm installed.
Old Nov 9, 2004 | 07:16 PM
servohead's Avatar
servohead
yeah clear all those codes out of there and see what comes back. As for your drivability problem, check your intake system connections to make sure that the maf is registering properly if you haven't already.
Old Nov 9, 2004 | 07:35 PM
Mike Mercury's Avatar
Mike Mercury
good suggestion
from another web site:
"Normal" codes: U1016 , U1064 , U1096
these three may appear on your car when you check for codes, but they will not set the "Check Engine Light". Don't worry about these codes, nothing is wrong if you keep getting these.
Old Nov 9, 2004 | 07:36 PM
LoneStarFRC's Avatar
LoneStarFRC
Bill C
The U1016H, U1040H and U1096H codes are something I've experienced pretty much ever since I've had the car (1st owner), both before and after a new battery (Red Top). They are history codes and of no real concern to me, other than the fact that they keep recurring after being reset. Oh well, at least these are not codes that pop up on the DIC.
Old Nov 9, 2004 | 07:44 PM
Mike Mercury
DTC P1626 Theft Deterrent Fuel Enable Signal Not Received
could this be a coulmn lock code?
Old Nov 9, 2004 | 07:48 PM
servohead's Avatar
servohead
Yeah I wonder. I know some years that the column lock recall is just a software upgrade where other years actually require some mechanical changes. To boot, my FOB stopped working after the Column lock recall was performed.
Old Nov 9, 2004 | 10:23 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I found it:
U1088 - Loss of Communications with SDM
http://myweb.accessus.net/~090/dtcobd2.html#net
To got codes!!!
