ECU ground
Old Nov 10, 2004 | 11:49 AM
Phil97SVT's Avatar
Phil97SVT
Default ECU ground
Where is the ECU grounded? I am having a problem with my logger and it was suggested to move the logger ground to where the ECU is grounded.
Old Nov 10, 2004 | 02:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I am at work and will provide you the info later this evening after i get home and can researck the manuals.. If I remember corectly there are MORE than just one PCM ground!
Bill
Old Nov 10, 2004 | 06:43 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Phil
The C5 does not have an ECU but I believe that you need the PCM ground locations
The Power Train Control Module (PCM) ground is located at ground location G-106 which is located on the engine block just above and fwd of the starter. It is a bitch to get to especially with headers!
There are 4 PCM ground wires that all tie together and ground at G106.
They are Connector C1, pins 72 & 76, Connector C2, pins 21 & 66
If you are talking about the Body Control Module, Please let me know and I will look that up also. There are a lot more grounds for that beast! The main BCM ground is G-104 which is on the top of the passengers frame rail inboard of the battery.
Bill C
Old Nov 10, 2004 | 06:56 PM
JAY KOCH's Avatar
JAY KOCH
Info from previous post showing ground point info.
http://forums.corvetteforum.com/showthread.php?t=939346
Good luck.
To ECU ground
