Electrical Plug question...
Old Nov 11, 2004 | 11:18 PM
Tom73's Avatar
Tom73
Default Electrical Plug question...
The '04 has a power take off located in the center console glove box. That is a bad location for something like a radar detector. So is it okay to use the cig lighter for a power point? I know that some cars say to not use the cig lighter as a power source, but what about the Vette?
tom...
Old Nov 12, 2004 | 07:58 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The cig lighter is an always on wire. Find a pink (ign) wire. I used the turn signal wires (3) and tapped the pink for a key on only power supply. But you can use any pink (NOT ATTACHED TO AN AIRBAG/SRS HARNESS)
Old Nov 12, 2004 | 11:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES you can use it BUT like it was said above it is always powered up.
BC
To Electrical Plug question...
