Newbie question
Old Nov 15, 2004 | 11:01 AM
jan55's Avatar
jan55
Default Newbie question
We are picking up our first Corvette today ...a 2001 convertible, and are pumped. As a new owner, what are some of the things we should be aware of, concerned about, watchful over. The car has 20,000 miles, is in great shape (I hope). Oil change is being done as well as general overall inspection. We want to get off on the right foot with this car so any ideas would be helpful.
Thanks,
Jan55
Old Nov 15, 2004 | 11:49 AM
mdhmi's Avatar
mdhmi
Welcome aboard and congrats on your purchase. Other than the CLB, which there is a recall for, you should be all set.
Don't forget to wave.
Mark
Old Nov 15, 2004 | 12:09 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Welcome, and enjoy. Almost all the fluids should have been changed or will need to be changed, I always do it anyway, never know what the prior owner did.
Old Nov 15, 2004 | 12:47 PM
TopCat's Avatar
TopCat
Don't forget to check under the battery and make sure any acid that has spilled under it has been neutralized, then put an Optima Red Top in and never worry again. Do a search on the forum @ batteries for the rest of the story. Welcome to the Forum
Old Nov 15, 2004 | 01:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree with SCREW99 !!
I have had two C5's (98 MN6 coupe and 02 ZO6) and an UP-GRADE to premimun fluids will significantly improvement the expierence!
I changed my 6 speed tranny fluid to synthetic (MOBILE 1 synthetic ATF) and synthetic rear end fluid with additional additative and saw a significant improvement in tranny shift feel and improved rearend clutch smoothness.
Brake fluid will need to be changed every 2 years of if it is getting dark.
Clutck master Cyl fluid must be changed if you have a manual
Check the radiator air inlet for leaves and trash!
Get the car up on jack stands or a lift and give it a good look. Look for any thing out of the ordinary (leaks, rust, bent or loose things and any missing items.)
The miles are low and if the car has been taken care of, looks like you should be all set.
There are a few things that will get you into trouble if you dont keep after them.
On the drivers side of the windshield cowl there are some drains that drain the water from the windshield cowl.
[IMG][/IMG]
THREE DRAIN UTTERS!
[IMG][/IMG]
reach your hand into the hole (it's easy if you have an automatic) and work any trach out of the drain tubes that may be in there. If they stop up it will destroy your wiper motor! READ $$$$$!
Yhere is a 90 deg rubber elbow on the passengers side fire wall area that is it AC/Heater box drain.
[IMG][/IMG]
If this drain clogs up, water/condensation will back up in the box and overflow in to the passengers foot well and wet your Body Control Module causing all sorts of weird electrical problems (every warning light in the book will come on )
Most people cut off the crimped end on the fitting to eliminate this problem
If it isnt already installed and you have a manual car, GET a Column Lock Bypass module and install it! Sooner or later the column lock will BITE YOU if you have a manual trans car! If you have not had the recall done and your car is effected, GET IT DONE!
Welcome aboard and ENJOY YOUR CAR! (DRIVE IT LIKE YOU STOLE IT!! )
Old Nov 15, 2004 | 01:21 PM
frank dupuy's Avatar
frank dupuy
Default vert
I reciently purchased my first corvette and it was a 04 vert. A4. I live in california so the top is down 90% of the time. I contacted mod fever. Installed Borla twin tip stinger exhaust Z06 sway bars Bilstine sport shocks and couldn't be happier. Nothing like looking up at the stars crusing along at 70 mph on a open road with 350 hp + at the right foot.
Old Nov 15, 2004 | 03:42 PM
tahoeC6's Avatar
tahoeC6
Default Congrats!
Don't overlook your air filter. One of the best upgrades you can do is install a K&N air filter. Enjoy, and don't forget to wave!
Old Nov 15, 2004 | 04:25 PM
jrose7004's Avatar
jrose7004
Enjoy your car and welcome!
Old Nov 15, 2004 | 05:47 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Looks like everything has been pretty well covered. Congrats on your purchase and welcome to the forum
Old Nov 15, 2004 | 06:00 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Old Nov 15, 2004 | 06:26 PM
ROMA 75's Avatar
ROMA 75
Welcome...and don't forget to
Old Nov 15, 2004 | 06:34 PM
VetteDrmr's Avatar
VetteDrmr
Originally Posted by jan55
... We want to get off on the right foot with this car so any ideas would be helpful....
That's usually NOT a problem!!!
Have a good one,
Mike
Old Nov 16, 2004 | 02:03 AM
GrayC5's Avatar
GrayC5
Welcome to the Forum ...and congrats on the new ride!
To Newbie question
