HELP F-45 Problems
Old Nov 17, 2004 | 09:40 PM
rob&dalevance's Avatar
rob&dalevance
Default HELP F-45 Problems
HELP! My 97 w/F-45 suspension has failed. It feels like riding on marshmellows now. No codes are stored. What could be wrong? The DIC did give a suspension inoperable message when it failed.
Old Nov 18, 2004 | 01:21 PM
fixvet's Avatar
fixvet
I can't help much, but I've read that when it fails...it will always set the shock valving to end up in the softest setting automatically.
I've got the F-45 option also. I'm dreading the day when my shocks are toast! New shocks run about $400 each, I've heard!
Ouch!!
Good Luck!
Old Nov 18, 2004 | 02:06 PM
Paras's Avatar
Paras
Hi, I'm sorry to hear that you're having problems with your suspension. If you do determine that your shocks have failed, I do have a set of shocks off of my '01 that I'm selling. Good luck
-Paras
Old Nov 18, 2004 | 08:59 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Go to the dealership and ask them to find the problem. If they find the problem is an expensive one and you are not under warranty, you can have them shut off the F45 controller so you can install any shocks on the car you like.
VR
Old Nov 19, 2004 | 12:09 AM
fixvet's Avatar
fixvet
VR
Does this apply to any model year with the F45 option??
Old Nov 19, 2004 | 12:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you throw in the towel, Let me look in the shop manual and see if I can find things to check.
BC
Old Nov 19, 2004 | 12:54 AM
vetterdstr's Avatar
vetterdstr
Yes it does
VR
Old Nov 19, 2004 | 01:08 AM
Paras's Avatar
Paras
True. I'd just like to add that I took the F45 shocks off and installed some coilovers for better handling. You can change the shocks to Bilsteins or '04 Z06s for better handling. I just offer the F45 for someone who wants to stick to the stock setup.
VR
Old Nov 20, 2004 | 08:21 AM
rob&dalevance
Ttt
Old Nov 22, 2004 | 10:45 AM
rob&dalevance
Anybody else??
Old Nov 22, 2004 | 11:07 AM
DirtyRed's Avatar
DirtyRed
Just another option, if you shocks are shot, you can upgrade to the F55 magnetic suspention. I saw that all cars originally equiped with F45 can be upgraded. Don't know the cost though. Check out GM performance website for addt'l info.
Old Nov 22, 2004 | 01:08 PM
vetterdstr's Avatar
vetterdstr
You can aslo have your F45 setup rebuilt for not too much money. A while back, someone was GIVING AWAY a F45 system to anyone who wanted it... so check the forum parts for sale section to see if that is still available.
VR
Old Nov 22, 2004 | 01:15 PM
chaase's Avatar
chaase
St. Jude Donor '12
That would be an expensive upgrade... The F55 was a $1500.00 in '03. If you thought the F45 shocks were expensive, the fluid in those shocks is rumored to be $800.00/quart!
Chris
To HELP F-45 Problems
