4L60E weak?
Old Nov 19, 2004 | 03:43 PM
Pug's Avatar
Pug
St. Jude Donor '08
Default 4L60E weak?
I have heard that the 4L60E is a bit on the weak side.
Is this true and if so what would be best to make it survive better?
I have looked here and found all kinds of stuff but not real sure what to get and how involved some of this is.
I may run a little juice later on but the whole "may blow up your A4" worries me.
Thoughts?
Old Nov 19, 2004 | 03:58 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Weak as water.
The 4L60E is notorious for failing. Usually the 3-4 clutchpack.
A number of things can kill it in short order. "Excessive" temperature, "excessive" horsepower and torque, manual shifting, or even if its the slightest bit low on fluid.
Of course "excessive" is a relative term.
Keep it cool, keep yourRW HP/TQ below 400 as 375-400RWHP is where they seem to eventually crap out. don't manually shift, expecially don't downshift it, make sure it's topped off and fluid is running out of the hole if you should ever refill it.
Old Nov 19, 2004 | 04:08 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
its funny that you post this. i just received my spare 4l60e and rear from ebaymotor auction. anyway i say this cause ill ordered ptk twin turbos and will be pushing some serouis hp 650 700. i currently have trans built by local guy JG transmission@ 215 659 3022. its been flawless and has transgo kit 4l65e plates and other trick w/tci 3800 stall. i spoke to kevin winstead at tci and new turbos we will build new tranny with tci rebuild kit, high strengh input, 5 planetary front and rear gear, heavy duty 3,4 servo kolen metal plates and red line plate and bunch of other stuff. call Kevin Winstead @TCI
read thishttp://www.ls1tech.com/forums/showthread.php?p=2017633#post2017633
Old Nov 19, 2004 | 04:12 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
ask the tuners who to use.
Old Nov 19, 2004 | 04:15 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We have destroyed a few
Old Nov 19, 2004 | 04:40 PM
Pug's Avatar
Pug
St. Jude Donor '08
Hehe not looking for 600-700 hp. (yet)
the car just has 2500 miles on it and all I would like to do is run maybe a 150 shot of juice on her without being to concerned about toasting the tranny.
would just the shift kit help?
Trans cooler?
larger servo?
Boost valve?
Or will I have to go into the trans to make it safer?
Old Nov 19, 2004 | 08:14 PM
blktie8's Avatar
blktie8
Default My trans guy
Rodney my 4L60 trans is great weather is not ...
I guess Jr's 4l80 will be done soon
Thanks for a great time and build (again)
John sr.
Old Nov 19, 2004 | 10:35 PM
Pug's Avatar
Pug
St. Jude Donor '08
John sr.
OOH can you swap in a 4L80E?
that would rock.
Old Nov 19, 2004 | 10:52 PM
NICK YOSKIN
St. Jude Donor '08
if your going to pull the tranny you might as well blow it up first!
serouisly beat on it and if it breaks , oh well then pull it. pulling and building the tranny is the same weather its blown or not.
Old Nov 19, 2004 | 11:26 PM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Old Nov 20, 2004 | 09:22 AM
vstella's Avatar
vstella
Originally Posted by EB20003
Weak as water.
The 4L60E is notorious for failing. ..Keep it cool, keep yourRW HP/TQ below 400 as 375-400RWHP is where they seem to eventually crap out.
..Once I hit 385 RWHP..I needed a complete rebuild!! Don't forget the Transgo shift kit ..PICs on the breakdown and rebuild on my CF homepage link below..Good Luck
Old Nov 20, 2004 | 09:25 AM
kirbyloid's Avatar
kirbyloid
Default Trans
Thoughts?
Call "crashed 94" Rodney he will take care of you!
Old Nov 20, 2004 | 08:26 PM
Hool97's Avatar
Hool97
Old Nov 20, 2004 | 11:14 PM
David426's Avatar
David426
Mine won't shift from 2nd to 3rd under wide open throttle sometimes. Clutchpacks bad 42,000 on stock 1999 C5. Should have bought a M6.
Old Nov 21, 2004 | 10:51 AM
blktie8's Avatar
blktie8
Default NO! 4l80 in the rear to my Knowlege
that would rock.
No!
Rodney built my 4l60 and is building a 4l80 for the 91 bowtie8 race car
All custom with a 9in rear gear
91 has the trans up front
If you Get a bullet proof trans the next weak link will show its ugly head.
RODNEY CAN DO THE TRANS.
To 4L60E weak?
