Front Cover Alignment
Old Nov 19, 2004 | 08:23 PM
vettenuts's Avatar
vettenuts
Default Front Cover Alignment
The manual calls out two special tools for aligning the front cover after a cam installation. LS1howto.com just bolts it back in after the damper is in position but there is a warning in the manual about doing that. Has anyone looked into the tools required by the manual? I know that the how to published by Vette Doctors does use the special Kent-Moore tools. Does anyone know where to buy Kent-Moore tools online?
Old Nov 19, 2004 | 08:35 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I just used the balancer to center mine and then tightened the cover.
Old Nov 19, 2004 | 08:57 PM
ArKay99's Avatar
ArKay99
Here is a link to thier webpage. Kent-Moore . Unfortunately you can't buy from them online. You need to call the number and order the part through an operator. The part you are referring to is around $85. I purchased the front cover seal installer for $40 and the balancer installer. I think the balancer installer was around $60. The balancer installer comes with a stud about 10" long that threads into the crankshaft and the front cover seal goes over it and you put a bolt and washer on it and crank it down and it presses the front crank seal in place. It fits the seal like a glove so you can leave it in place and tighten the front cover with that up against the cover. I also used it to install the crank sprocket and my new ASP pulley. But if you don't want to spend the money, the LS1Howto methed will work.
To Front Cover Alignment
