Chirping noise decelerating
Old Nov 26, 2004 | 07:08 PM
servohead's Avatar
servohead
Default Chirping noise decelerating
A faint chirping/squeaking noise when I decelerate is the topic here. I'm pretty sure it is my tensioner pully, but out of curiosity is there any history of driveshaft/outputshaft squeaking noises at all?
Also, I'd like to change my tranny fluid (M6) How do you fill it up after you drain it? Do most of you use synthetic?
Old Nov 26, 2004 | 07:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Autozone and Advance Auto Parts sells a fluid bag (Its kind of like an IV bag) that you can load up with your fluid of chioce and squeeze it into the tranny! There is a fill plug on the side of the MN6 /MN12 tranny that you remove and add the fluid until it starts to run out of the fill port.
I highly recommend using a synthetic ATF for the manual tranny. It improves the shift feel a lot!
Bill C
Old Nov 26, 2004 | 07:54 PM
servohead's Avatar
servohead
I saw that someone was using "redline" fluid. Is this a good choice? Also, I am suprised that you actually put automatic transmission fluid in our manuals.... does GM make an M6 "manual trans fluid" of sorts? Thanks for your advice I'll look around for one of those fill bags!
Old Nov 26, 2004 | 08:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
All C5 MN6 and MN12 (ZO6 Manuals) use ATF tranny fluid! GM has it own specific ATF. Redline, AMSOIL, Mobil 1 synthitic ATF are all very good up-grades! I was surprised to!
PLEASE do not put motor oil or 90 weight in the trans! You will destroy it!
Old Nov 26, 2004 | 09:43 PM
servohead's Avatar
servohead
ok cool, thanks Bill. I think I'm going to go with some Synthetic mobil 1 ATF - maybe I'll do that tomorrow even if I get bored... I'm just curious what fluid do you run in yours?
Old Nov 26, 2004 | 10:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mobile 1 ATF synthetic! No need to run anything else! It's good stuff!
Old Nov 27, 2004 | 12:03 AM
servohead's Avatar
servohead
alright thats it I'm doin' it!
Old Nov 27, 2004 | 12:18 AM
Dirty Howie's Avatar
Dirty Howie
I assume this would be a good choice for us A4 guys also?
Old Nov 27, 2004 | 01:01 AM
servohead's Avatar
servohead
That's actually a good question. It depends on the year but the volvo S-80's use a GM transaxle and use regular ATF.
To Chirping noise decelerating
