E-Brake/Idle Problems on Used 2000 C5
Old Nov 29, 2004 | 02:46 PM
aggressr's Avatar
aggressr
Default E-Brake/Idle Problems on Used 2000 C5
I think I have the opposite problem as some of you,
I have a 2000 C5 and at a stop light or from a standstill,
taking my foot off the gas has no effect, the car does not
roll at all.
My chevy dealer said the brake was adjusted properly
and had no other suggestions.
Any Ideas on what would keep it from rolling forward?
thanks guys, I am kinda new to this Corvette thing, I am a new F-body convert. The car runs great and is in excellent shape and
of course I am fixing her up with some minor mods, 18/19s, new rubber and some nice touches.
thank you!
Old Nov 29, 2004 | 06:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did you mean "Take my foot off of the brake" vise take my foot off of the gas??
What is your idle speed when the trans is in Netural and while in Drive?
Do you have any kind of warrenty? If so keep complaining. Could be a torque converter problem. You got the car used and I am wondering if you might have an aftermarket high stall converter.
Check into that before you start having the dealer rip into it. I have all manual cars and do do much with automatics.
Just a thought!
Bill C
Old Nov 29, 2004 | 06:47 PM
aggressr's Avatar
aggressr
Hi Bill, thanks for the reply...
I did mean the brake, like at a light, it is almost as if the car is on a slight incline...just no idle roll. It doesn't creep forward like my Trans am did or any other automatic I have driven.
I think maybe something is grabbing, rear brakes, etc.
I have no warranty, but the car only has 39k on it and was serviced regularly at the same dealer. The car is very fast, and drives fine otherwise.
I will check that idle RPM in neutral and drive and repost...
thanks
IM QUIKR's Avatar
IM QUIKR
Just a thought!
Bill C
My thoughts exactly
Old Nov 29, 2004 | 06:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is something that you can do to rule out the brakes or a rolling componet problem.
You can drive the car to a flat level area. Get the car to do the condition that you stated, shut it off, put it in netural with the E brake off, get out and while standing in the drivers side with the door open, PUSH IT! I can just about push mine with one hand! It should roll easy! I would roll it far enough to get 2-3 tire revolutions just to make sure that nothing is position sensitative.
If it rolls easy, I would rule out the brakes dragging.
BC
Old Nov 29, 2004 | 07:09 PM
aggressr's Avatar
aggressr
Ok, I checked the Idle and at cold start in Park was 1000 RPM strong
10 minutes, Drive and Reverse both brought idles of .75 RPM
with a shift back into park or neutral just under 1000 RPM
there are no other mods done to this car, I am not sure why he would have installed that stall converter.
Could a vacuum problem be causing this? or a hung e-brake?
thanks!
Old Nov 29, 2004 | 07:19 PM
IM QUIKR's Avatar
IM QUIKR
Never forget about the obvious. Does it have enough tranny fluid?
Old Nov 29, 2004 | 08:07 PM
servohead's Avatar
servohead
I've seen alot of GM transmissions/transaxles do this, but never really thought that it was a serious issue. But that's just my own experience...
Old Nov 29, 2004 | 08:25 PM
CHJ In Virginia's Avatar
CHJ In Virginia
It seems to me that your idle speed is too high. My bone stock 2001 idled at 700-750 rpm in or out of gear, not much difference either way. The car had a 3:15 perf axle ratio and would definitely creep when in gear at idle with no brakes - 5-6 mph. As recommended in previous posts, check the brakes and tranny fluid.
Old Dec 4, 2004 | 03:05 PM
aggressr's Avatar
aggressr
Bill, thanks for your reply. I had a shop put my Zo6 motorsports on last night and they called me to ask what was wrong with the car, they could not roll it on to the rack, even with the Ebrake off. It seems to "tighten" up only when it gets hot, I have some idle roll when things are cold, but once things get hot, from a dead stop the car barely moves, and you have the hit the gas somewhat hard to get her moving.
They replace pads on the front and took the calipers off to paint them, and said other than the rotors being purple (from high heat) they were fine. Could this still be the rear brakes catching when the car is rolling?
thanks!
Brian
Old Dec 4, 2004 | 03:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brian
It sounds like the pins that the calipers slide on are NASTY! There are two pins per caliper and the rubber boots that protect each pin has to be in good condition. I recommend removing each caliper and cleaning each pin and the well in caliper with carb cleaner. You MUST use the correct type of special synthetic caliper grease on the pins or this will happen again! NAPA sells it as does AutoZone and advanced auto parts.
You could also have pistons that are getting stuck in the calipers. You can yse a pry bar to pry on the caliper and chove the pistons all the way in the calipers. then pump them back out. Do this 4-5 times and see if that helps.
My bet is it is just the caliper pins causing the caliper to hang up! Been there!
If you need to please call me. Contact me by PM.
Bill Curlee
To E-Brake/Idle Problems on Used 2000 C5
