Piston slap, what to do?
Old Dec 2, 2004 | 07:53 AM
PaPaChoc's Avatar
PaPaChoc
Default Piston slap, what to do?
I know this has probably been asked a 100 times but being a newbie I thought I’d ask again.
Before I got my C5 I was under the impression that the LS1 was an aluminum version of the Chevy SB. Boy was I wrong! From what I have read on these boards these engines and drive trains are nearly bullet proof! If taken care of they should last a long time.
Now, my car has what’s been called “Piston slap”. I got the extended warranty when I got the car. It is due to run out at 78,000. Should I start beating on my dealer about the problem now (48,000) or wait? Or should I even be concerned with it? I use my car as a DD, I don’t abuse it, and don’t have any intentions of doing any thing to it but drive it.
I would hate to get to 80,000 and grenade it like I did my last Vette engine. My 427/435HP Tri-power looked like a hand grenade went off in the oil pan!
Thanks!
Old Dec 2, 2004 | 08:09 AM
AU N EGL's Avatar
AU N EGL
Piston slap is not that uncommon with LSx motors.
How often do you change your oil and how long do you let your car / oil warm up before driving??
If I may suggest to let the engine and oil warm up to a tleast 80 degrees F before driving will help some.
Good luck
Old Dec 2, 2004 | 01:07 PM
PaPaChoc's Avatar
PaPaChoc
I've started to let it warm up before driving it. But mostly I'm concerned with the long range effect.
To Piston slap, what to do?
