LS2 Timing Chain on LS1
Old Dec 3, 2004 | 10:37 AM
DTSNGIT's Avatar
DTSNGIT
Default LS2 Timing Chain on LS1
Has anyone converted timing chains to gain strength? I was just wondering what all is needed to complete this swap? Obviously the chain but how about cover, gasket etc..etc....
Thanks for the input,
Mike
Old Dec 3, 2004 | 11:02 AM
Patches's Avatar
Patches
Sidestep just installed an LS2 chain on his '01 LS1 when he did his h/c and didn't need anything else for the chain to fit. He sent me a pic and is looks much stouter than the LS1 chain.
Old Dec 3, 2004 | 12:20 PM
DTSNGIT's Avatar
DTSNGIT
Thanks....... I was thinking that was all I needed as both motors use the same cover gasket.
Mike
Old Dec 3, 2004 | 01:15 PM
see5's Avatar
see5
I did it. It is direct replacement and from the looks of it more than you will ever need.
Old Dec 3, 2004 | 01:17 PM
Vector's Avatar
Vector
Don't most tuners use/recommend double roller chains with H/C upgrades? They are readily available. Wouldn't this be a solution. I don't recall reading of any timing chain failures on stock LS1's. Am I missing something?
Old Dec 3, 2004 | 01:28 PM
see5's Avatar
see5
IMHO the doubles were the only good option before this LS2 came out 6 months ago. Now if you are really anxious you can do the LS2 chain and this which let you rev it till the pistons fly out..
Old Dec 3, 2004 | 01:38 PM
Vector's Avatar
Vector
Ahhh! I see! That, LS2 chain should take a bit of thrashing and do just fine! And spockets match up. Glad I don't make a living building double roller chains for LS1's.
Old Dec 3, 2004 | 01:49 PM
SnowyATX's Avatar
SnowyATX
Mike
I put one in last week during my heads/cam swap. Direct replacement...nothing special needed.
Old Dec 3, 2004 | 09:08 PM
Greg_E's Avatar
Greg_E
Did you install the damper (if that's what it's called) shown in the picture when you did the chain?
Doesn't that cost almost as much as the chain?
Old Dec 3, 2004 | 09:15 PM
SnowyATX's Avatar
SnowyATX
I did not put in the damper....and yes I believe its fairly pricey.
Old Dec 3, 2004 | 09:35 PM
see5's Avatar
see5
Damper is about $90 for nylon or somthing similiar. Probably overkill in most cases.
Old Dec 3, 2004 | 10:18 PM
C5XTASY's Avatar
C5XTASY
Is it called a tensioner for the chain?
Ed
Old Dec 3, 2004 | 10:33 PM
see5's Avatar
see5
GM PART # 88958608 now # 12586482
CATEGORY: Belt or Chain, Engine Timing
PACK QTY: 1 CORE CHARGE: $0.00
DESCRIPTION: CHAIN
From the 2004 GM Performance Parts Catalog: page 106:
88958607 Timing Chain Damper, LS1, LS6
“This timing chain damper is intended for high engine speed applications and is used to improve timing chain life. Some blocks require drilling and tapping- an instruction sheet is included. “
GM PART # 88958607
DESCRIPTION: DAMPENER
Old Dec 4, 2004 | 07:30 AM
vettenuts's Avatar
vettenuts
"Some blocks require drilling and tapping- an instruction sheet is included. “
Any idea which blocks require the drilling/tapping?
Old Dec 4, 2004 | 08:14 AM
see5's Avatar
see5
I have heard early and late blocks were tapped. My 2000 was not. It is pretty easy, even in car. 8mm
Old Dec 4, 2004 | 07:40 PM
vettemaster1's Avatar
vettemaster1
i just installed the dampner and gm high performance chain....the chain looks like the ls2 one....my 98 block was drilled and tapped for the dampner....also degreed the cam at that time....
To LS2 Timing Chain on LS1
