Weird Code 0440???
Old Dec 4, 2004 | 10:06 AM
Kevin McGrade's Avatar
Kevin McGrade
Default Weird Code 0440???
0440 on the dic after a five minute cruise. Can't find this code on any of my resources.
Old Dec 4, 2004 | 10:17 AM
RWhite's Avatar
RWhite
DTC P0440 Evaporative Emission (EVAP) System
Old Dec 4, 2004 | 10:18 AM
Kevin McGrade
??? wonder what that is
Old Dec 4, 2004 | 10:21 AM
RWhite's Avatar
RWhite
Do a Google search. There are a lot of posts about this problem.
Just search "P0440 dic code". I'll go out in the garage and look in the shop manaul and see what it says.
Old Dec 4, 2004 | 10:31 AM
RWhite's Avatar
RWhite
Conditions for setting the DTC:
The EVAP system is not able to achieve or maintain vacuum during the diagnostic test.
I copied these from a few posts:
"Did you check to make sure the gas cap is tight?"
"Check the lines at the evap cannister and make sure the one running to the tank is connected."
It is in the fuel vapor portion of the emissions. double check the fuel cap is tight and the lines to evap purge solenoid and evap vent valve have not come off or leaking a little."
Old Dec 4, 2004 | 10:34 AM
Jerseyboy's Avatar
Jerseyboy
Tighten the gas cap and try again :-)
Jersey
Old Dec 4, 2004 | 04:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I put a little silicone grease on my gas cap every once in a while. It seem to keep it plyable and help it seal. I lube it up good prior to taking it to the emissions station! They like to fail gas caps!
Bill
To Weird Code 0440???
