Can anyone tell me how the engine cylinders are numbered.
Which is number 1, Number 2, ect.
Is the numbering scheme (which is 1, & which is 2, ect.) the same for all vehicles and engines, or do different manufacturers use different numbering sequences?
And this is a change from the firing sequence that was used for many many years by most, if not all, the GM divisions. It used to be 1-8-4-3-6-5-7-2.
This is true and I've always been curious as to why they changed it? Does anybody have an understanding of the technical reasons they would have done this?
I think one of the reasons was to smooth out the engine at idle.
• The Gen III firing order has been revised from 1-8-4-3-6-5-7-2 to 1-8-7-2-6-5-4-3. Note that the pairings 1-8, 4-3, 6-5, and 7-2 remain the same, but the pairing order is different for reduced vibration.
