Code C1281
Old Dec 15, 2004 | 11:36 PM
98 corvette's Avatar
98 corvette
Default Code C1281
I know what this code is I just need to know what is causing it and what needs to be done to fix it thx.
Old Dec 15, 2004 | 11:42 PM
JUSTIFIED C5's Avatar
JUSTIFIED C5
I have same code, would love to know what needs to be fixed.
Old Dec 15, 2004 | 11:44 PM
98 corvette
How often dones yours activate, and when?
Old Dec 16, 2004 | 12:04 AM
JUSTIFIED C5
It started happening ever since I pulled my motor out last spring for upgrades. I clear the code every time I drive the car. It comes on after about 5-10 miles every trip. Really annoyning though. Just learned to live with it. I started pulling my motor again tonight for new 427 hopefully find something that would be cause of problem.
Old Dec 16, 2004 | 01:05 AM
98 corvette
Great let me know if you find out anything, by the way is the 427 the way to go for a good engine swap?
Old Dec 16, 2004 | 10:43 AM
Jeff Jeff's Avatar
Jeff Jeff
1281 is the steering sensor. PM me if you would like me to email you instructions to fix it.
Since you had your engine out, you may have put your steering shaft in 180 degrees off and the sensor meay be OK. I think this will cause the problem.
To Code C1281
