Why does a 427ci cost so much?
What would it cost to build an identical quality 427ci at home if one shopped around for the best prices on the parts?
Darton LS1 block with line hone and bores finished $3000
Rotating assembly with bearings and rings $3000
AFR 225 heads $2400
Cometic Gaskets $150
ARP head studs and main studs $400
$8700
You will reuse your factory oil pan, sensors, covers and reusable gaskets. The stock oil pump can be easily ported and shimmed for more oil pressure.
Phil
AFR 225 heads $2400
Vararam intake $350
Long tubes $1400
Fast 90mm intake and 90mm TB $1025
42lb injectors $300
Mufflers $700
Clutch/flywheel: $750
ASP dampner $250
~14,000
AFR 225 heads $2400
$8700
Phil
Been shopping around for a big cube motor, but any reliable place want's 20G's and up.....
AFR 225 heads $2400
Vararam intake $350 (Already have Vortex)
Long tubes $1400 (Already have TPIS)
42lb injectors $300
Mufflers $700 (Already have Flowmasters)
ASP dampner $250 (Already have ASP UD Pulley...but may need to be swapped)
~$14,000 (TOTAL ADJUSTED COST ~$11,000)
So the tuners are making about $5K-$6K in labor/markup....sheeeesh!
Let's hope the new C6 Z06 427ci will be a cheaper alternative....and be an easy swap into the C5.
AFR 225 heads $2400
42lb injectors $300
AFR 225 heads $2400
42lb injectors $300
If some one can do it for less and STAY in business, more power to them.
IMHO if you would like a 427ci and dont want to pay for it, build one yourself. Afterall, its only a few parts bolted together, isn't it??
I think the pricing for these will be sub $10k
...or, maybe it's because they can?
...or, power costs, how much ya want?
...or...
All the best.
With that being said i'd appreciate it we can stick to the orginal questions of:
Why does it cost $20K for a 427 turn-key package? Is that cost mostly parts, mostly labor, or about half of each?
What would it cost to build an identical quality 427ci (turn-key package) at home if one shopped around for the best prices on the parts?
AFR 225 heads $2400
42lb injectors $300
I doubt you will a warranty if it is installed in the wrong vehicle.
We do an all new resleeved LS6 block and AFR head 427ci base installed and tuned package with injectors, cam, pushrods, oil pump, lifters, etc. for $14595 that requires only your covers and is used on cars having all the normal bolt-ons such as cold air intake, headers, cats, exhaust, etc. There are sevearl "small parts' that add up that a lot of folks don't realize. Add ons would be 90mm LSx intake and 90mm TB and UD pulley beyond the normal longtube headers, hig flow cats, catback exhaust, fuel system, and so on. And of course everyone wants a warranty on a race engine.
This a pretty broad statement as far as add-ons and we usually discuss each vehicle with the customer for a custom package matching your needs.
Hope this helps.
Mike Norris
Hope this helps.
Mike Norris
