temp. control,how?
Old Dec 17, 2004 | 09:06 PM
2pedala's Avatar
2pedala
Default temp. control,how?
Okay, 2003 vette here in fl. it runs 220 plus a few. an its winter. ive been told thermostat change is not enough fan setting has to be changed .ive had 58 an 67 no programing there. so do i have to buy some reprogrammer or do shops have capabilites.?
Old Dec 18, 2004 | 12:42 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
A reprogramer will work, a tuner has a programer, or you can buy a Vinci fan controler, a thermostat and fan controler (all in One ) or a hayden fan controler from pep boys, they are around 50 dollars, this is the most inexpensive route.
Old Dec 18, 2004 | 10:00 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
The biggest advantage of programming is that it's more easily reversible, biggest downside is cost.
Old Dec 18, 2004 | 11:22 AM
Evil-Twin's Avatar
Evil-Twin
a Vinci or a hayden controller is easily reversable.. you just turn it off.
the hayden controller 49 dollars is the best bang for the buck,, the Vinvi is just a Hayden with all the wires cut to a specific length for a C5 and instructions specific to a C5..There is a Tech tip on the C5 tech tip section about how to install a hayden controller..
I use a Vinci and it works perfectly.. when I run my 160 stat in the summer I use the Vinci controler.. in the winter I turn it off and put my 190 stat in and use the factory programmed settings .
Old Dec 18, 2004 | 01:20 PM
ToplessTexan
I was referring to actually removing the mod, not just disabling its functionality. Can be a factor for leased cars.
To temp. control,how?
