My 99 is running rough
Old Dec 19, 2004 | 09:01 PM
hueyhue's Avatar
hueyhue
Default My 99 is running rough
From time to time it bogs/misses if I'm on the gas or not.
I just got the car. Any ideals?
Old Dec 19, 2004 | 09:13 PM
C5dream's Avatar
C5dream
Might have a bad spark plug wire. Probably should inspect each wire for cracks.
Old Dec 20, 2004 | 12:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wires and plugs are the most likley suspect! The resistance of each wire should be 250-750 ohms. The boots and jackets should be free of nicks, tears, cuts and corrosion.
If the plugs have more than 30K on them, I would change them!
See if you are throwing any codes! Please post them. After you write them down, Clear all of them.
Bill
Old Dec 20, 2004 | 12:48 AM
BlackMagicC5's Avatar
BlackMagicC5
I'd say its time for a tune up, if that hasn't been done yet.
Old Dec 20, 2004 | 04:34 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Bill
yep....its time for new wires....BTW do you know when the last time the fluids were changed and the belts??? Its about time at 5 years if those things haven't been done as well.....
Old Dec 20, 2004 | 01:29 PM
hueyhue's Avatar
hueyhue
Thank you all.
Old Dec 20, 2004 | 03:36 PM
radouspad's Avatar
radouspad
Cruising
I would consider several other things besides tune up related repairs, such as is the check engine light coming on when bogging happens, if so there should be stored dtc's. also check fuel pressure, fuel filter restriction , exaust system restriction , poor spark voltage
good luck;
gerry@radouspad@juno.com
To My 99 is running rough
