Best Header Size?
Old Dec 21, 2004 | 10:29 AM
AN1313's Avatar
AN1313
Default Best Header Size?
I'm looking for opinions on the best Kooks header primary pipe size (1 3/4" or 1 7/8") for an intake only 2002 Z06?
Also, who has the best price right now?
Old Dec 21, 2004 | 10:31 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
1 3/4 without a doubt. 1 7/8 are designed for larger displacement motors.
Old Dec 21, 2004 | 11:29 AM
AN1313's Avatar
AN1313
I agree, but MTI only carries the 1 7/8" version and Nick at Kooks stated there are great gains to be had on a stock sized motor with these. I'm still thinking about going with the 1 3/4", but would love to see a before and after graph with the 1 7/8".
Old Dec 21, 2004 | 12:04 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
But I think your decision is contingent upon future mods. If you plan to install a blower at some point/forced induction, the 17/8 are probably for you. Other wise the 13/4 should serve most other applications
Old Dec 21, 2004 | 12:48 PM
Pio's Avatar
Pio
What about the BPP headers, diameter starts at 1 . 3/4 then goes to 1. 7/8? Any thoughts on that design?
Old Dec 21, 2004 | 04:23 PM
2KREDVert's Avatar
2KREDVert
Go with the 1 3/4" DynaTechs, they are also SS so you don't have to coat them. The steel ones rust out quick, from the inside out, if you don't coat them. With most applications, the 1 3/4 will give you better bottom end. There are some complex formulas to calibrate optimum header size but the bottom line is that the 1 7/8 will help at the higher RPMs. Depends on where you want the power and a number of other factors. For most of us street guys, 1 3/4" is best. Bigger is not better when it comers to headers. Most experts will tell you to err on the smaller side. Car Craft did a nice article back in Dec. 2003 on how to properly size headers for application. What I told you was their bottom line.
Old Dec 21, 2004 | 05:40 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
1 3/4 for a 346ci
Old Dec 21, 2004 | 06:37 PM
1BAD-LS1's Avatar
1BAD-LS1
I have the 1 3/4 with an ATI Procharger, they work and sound great.
See the sig for details
Old Dec 21, 2004 | 07:30 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Please, dont buy anything bigger than 1 3/4 for stock displacement applications. You wont see much of a gain if any, going 1 7/8.
I have been there and done that.
Thanks,
Nate
__________________
Corvette Garage Inc
Xtreme Motorsports
1.806.863.3800
Website: Click here for Corvette Parts and Accessories!
Email: sales@corvettegarage.com
Old Dec 24, 2004 | 05:16 AM
LS1LT1's Avatar
LS1LT1
Look at the new Tri Y design long tubes from QTP as well.
www.quicktimeperformance.com
Old Dec 25, 2004 | 12:28 AM
J-Rod's Avatar
J-Rod
1 7/8" is too big for almost any 346 unless you turn way more RPM than any Hyd. motor can turn. Its a pretty simple fact...
Here is the math for tube sizing...
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
Exhaust Valve Opens - EVO
You'll find on most avg 346" motors 31-32" primaries and ~1.7x tube size is the math you come up with...
To Best Header Size?
