BPP shifter mod (reduced vibration)
http://forums.corvetteforum.com/showthread.php?t=978426
Dope
The other things I did to slow down the vibes were using RTV under the shifter base and using the plastic wedge inbetween the shifter arm and the lower shaft.
Nice job on the shifter.
I don't suppose you did a before/after to see if it actually did anything? When we last talked, we discussed weight changing the resonant frequencies of the shifter. I agree this is most likely the key to quieting the shifter.
I have a Hurst and it is as quiet as stock, however I have the MGW **** and I think that is effectively dampening any vibration.
I hate the way my car shifts. I can't blame the Hurst, the tranny is really notchy and unrefined. I can feel the syncro then the gear on every shift. Even with the stock setup, sometimes I had to rock the car forward to get into reverse. I believe my car now shifts slower than stock, unless I am willing to jam that sucker to shift.
A friend has a Boxter, what a difference shifting his car. He cannot drive mine due to the shifter. He can't get it into reverse, then never can find the right gear.
I think we really put up with allot with the crappy tranny in the Vette. I cannot remember driving a worse shifting car.
That said, the Hurst has made it better, but I'm still not happy.
Thanks for letting me rant.
I do admit that 1st and 2nd can be notchy sometimes. You just gotta use a little muscle.
Dope
I agree that the perfect shifter/tranny would allow short throws with little effort. With our C5s, we get long, mushy throws that are easy as slicing through butter, or short, somewhat precise throws with purposeful effort. Stock, our cars can be driven by any weakling, but with the short-throws, only real men like em!
Weighting the shift **** is another option when reducing vibration, but a metallic **** has its deficiencies as well. Hot in Summer and ice-cold in Winter is something I put up with in my 68 with the chrome ball shifter. I decided that I wouldn't go back to a metallic shifter, so weighting the shifter itself was my second option and it seems to work well.
Dope, the Hurst and BPP are similar in feel, but the BPP is adjustable to the driver's ergonomic requirements, whereas the Hurst is a "What you see is what you get" style.
All the best.
All the best.
The steel collars would certainly reduce vibration as well by simply increasing the mass of the shifter arm. A heavy **** is an added bonus if it doesn't have loose-fitting thread adapter inserts within it.
As you can see, there is more than one way to skin this cat! However, the geometry of the BPP shifter that makes it so very customizable, also make it a bit more difficult to calm down (so to speak). Needless-to-say, I like the many different ways that I can configure it to match my anatomy - well worth the anti-vibration efforts, IMO.
