anyone using GM Synchromesh??
Old Dec 28, 2004 | 03:54 AM
Z06Fix's Avatar
Z06Fix
Default anyone using GM Synchromesh??
I know alot of the Cobra owners and other mustang owners are making the switch to it. Also DSM owners swear by the stuff. I'm thinking of trying it but I dont want to void the warranty with something stupid like a fluid!
Eric
Old Dec 28, 2004 | 07:20 AM
vettenuts's Avatar
vettenuts
The only negative I have seen was that the long term effects on some non-metallic parts were unknown according to the transmission manufacturer. Everyone using it seems to be happy with the results. For now, I stuck with Amsoil and will wait and see what happens with this fluid.
Old Dec 28, 2004 | 07:45 AM
IMQUIK's Avatar
IMQUIK
Only the good stuff!!
Old Dec 28, 2004 | 08:21 AM
LRD VDR's Avatar
LRD VDR
I love that crap!! I use it in my T-56 in my Single Turbo Mustang with a 427 and in my Twin Turbo 300 ZX! Best of all the fluids I have ever used, and I have used a ton of other products. Great stuff!!
Shahram
Old Dec 28, 2004 | 08:27 AM
RWhite's Avatar
RWhite
When I had my '97 Cobra with its grinding 1-2, 2-3 shift, I changed to the GM Synchromesh fluid and the problem disappeared. Never had any long-term reliability problems. Drove the car for 50K plus miles.
Old Dec 28, 2004 | 12:03 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Eric
Eric,
If the fluid meets DEXRON III requirements, you won't invalidate your warranty. I'm not sure if the GM synchromesh meets DEXRON III requirements. I know the AMSOIL ATF does.
AMSOIL ATF
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 28, 2004 | 01:07 PM
66ImpalaLT1's Avatar
66ImpalaLT1
It does not meet Dextron III. I use it, and its great.
Old Dec 28, 2004 | 01:15 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I ahve used this in 6 different Vettes and to date no one incuding myself has had a problem or a complaint.
Old Dec 29, 2004 | 12:32 PM
FKING1's Avatar
FKING1
Have Redline in my Vette and GM in my 04 Cobra. Made the Cobra shift smoother.
Fred K.
Old Dec 29, 2004 | 01:30 PM
atz06's Avatar
atz06
Redline only on mine. Works fine.
Old Dec 29, 2004 | 01:49 PM
VetteTech81's Avatar
VetteTech81
Amsoil!
Old Dec 29, 2004 | 04:00 PM
Pumba's Avatar
Pumba
Eric,
Read the attached before you switch because of other's opinions:
http://www.svtperformance.com/forums...threadid=24048
Old Dec 29, 2004 | 07:47 PM
C66 Racing's Avatar
C66 Racing
Originally Posted by Pumba
Eric,
Pumba,
Very interesting read. Thanks.
Old Dec 29, 2004 | 10:34 PM
HurricaneZ's Avatar
HurricaneZ
I use it with only the best of results
Old Dec 29, 2004 | 10:58 PM
Cruncher's Avatar
Cruncher
I just had my fluid changed with GM Synchromesh, under warranty on 12/27/04. The mechanic told me that he uses it exclusively unless an owner brings in their own fluid. His experience has been that most people will not see a difference between the regular ATF and the synthetics. He said that the Synchromesh performs excellent in that the shifts will be smoother and the noise will be reduced & will not breakdown like regular ATF. Synchromesh is what the dealer uses and will not void any warranty. The Synchromesh is a partial synthetic fluid. If you have read other threads on tranny fluid, you will see that many people have had problems with synthetics. I was a little skeptical; I contacted a few Tremec rebuilders and all but one recommended GM Synchromesh as the fluid (I found rebuilders using Google). The car shifts smoother (I have a B&M shifter) and I have virtually no tranny noise since changning to GM Synchromesh.
Old Dec 29, 2004 | 11:31 PM
C66 Racing's Avatar
C66 Racing
If, as mentioned above, GM Synchromesh does not meet DEXRON III requirements, then I don't see how this can be true. Just because your dealer uses it doesn't mean it meets GM requirements.
While I'm obviously a little biased, I personally would be very hesitant to put anything in a car under warranty that doesn't meet the manufacturers specification and I'm pretty certain that for the MN6/MN12 gearbox, that requirement is DEXRON III.
Old Dec 30, 2004 | 08:03 AM
Cruncher's Avatar
Cruncher
Then why does GM have the stuff? Before I switched to Synchromesh, I did a search of it. Synchromesh was created by Pennzoil to solve specific problems relative to Tremec transmissions, specifically for GM. My fluid was changed under warranty. GM paid for fluid and the labor. The Sychromesh costs about $10/qt. You are more than a little biased: if Amsoil has it, you'll sell it, no matter what it is. Does Amsoil make any of their products? I am sure that ExxonMobil (i.e. Mobil1) spends more money in one day on research and testing than Amsoil has spent in the last 5 years. Mobil developed the specs for their filter; Amsoil only rebranded someone else's filter. The owner's manual calls for a PF46/44 filter, not an Amsoil filter......but I am sure that you use the rebranded filter, even though it is a different specification than a PF46/44. By the way, GM Synchromesh does not meet the Dexron III requirement.
To anyone using GM Synchromesh??
Old Dec 30, 2004 | 10:06 AM
Mikelly's Avatar
Mikelly
I had a Notchy T56 out of a 1995 Firebird that I stuffed into a datsun 260Z, along with a 383 stroker. I used Syncromesh from day one in that tranny and after the first 1000 miles I drained the fluid, based on the comments made about the tranny by the previous owner... I ran 10:98s several passes in that car with that tranny and GMs Syncromesh and after the initial fluid swap at 1K miles, the thing shifted like butter and was quiet with no gear noise at all... It is good fluid, and I'd use it again!!
Mike
Old Dec 30, 2004 | 10:07 PM
VERYSOON's Avatar
VERYSOON
cruncher
gm synchromesh is made for another transmission in the gm line, I forget which one.
I spent a great deal of time looking into this and the similar royal purple product. Neither meet the dexron lll spec. I have checked with some of the tuners here. Some say it voids the warranty, some say the opposite.
My conclusion was to use a synthetic atf and not travel into these waters. My warranty is for another 6 years so I pay attention to these specs. Synthetic atf has a huge advantage in operating temps over nonsynthetic atf. Planning for a bit of track time convinced me I need a higher heat capability for my MN6.
I do believe your criticism of Subdriver is unwarranted. His use of Amsoil is based on research, race application, positive experience and desire to help and inform. Income to him is negligible from these sales. (Cush salary from United States as a naval officer, with a bit of personal risk thrown in to make it interesting.)
all the best from
verysoon
Old Dec 30, 2004 | 10:24 PM
Tsab's Avatar
Tsab
I'm using it in my MN6 trans and it works fine.
