HELP!! Column Lock Problem
Old Jan 2, 2005 | 07:12 PM
HPfisterer's Avatar
HPfisterer
Default HELP!! Column Lock Problem
I need some help. I have a 2000 coupe. GM issued a recall for the column lock problem so I had the car serviced about 8 weeks ago for that issue. I've never had a problem with the locking mechanism, until now. As I was backing the car out of the garage I heard the locking mechanism engage and the steering wheel lock. The DIC read "Service Column Lock". I pulled the car back in the gargae and turned off the ignition. I then restared the car and the column lock disengaged however the DIC message is still there. I followed the instructions in the manual where it says remove the key for 10 seconds to acknowledge the warning, then restarted the car but the message still appears. The locking mecahism now doesn not seem to engage at all when the car is turned off.
Is there a simple fix for this I can do myself? Can I drive it back to the dealer? Should I tow it back to the dealer? I'm afraid that it may engage while I'm driving it.
Thanks in advance for your help.
Old Jan 2, 2005 | 08:30 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Pulling #25 BCM fuse at the passenger footwell and reinstalling it will reset the BCM for a column lock that is stuck in the "unlocked" position Then I suggest that you get the aftermarket bypass because if you have an M6,GM does not have a solution for you
Old Jan 3, 2005 | 08:05 AM
HPfisterer's Avatar
HPfisterer
Thanks. I'll give that a whirl. One question, exactly where are the fuses located in the passanger footwell?
Old Jan 3, 2005 | 09:01 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
under panel beneath floormat
buy a CLB kit
Old Jan 4, 2005 | 11:10 AM
HPfisterer's Avatar
HPfisterer
Thanks guys!!. I pulled #25. When I plugged it back in the colum lock engaged and now all is well.
Old Jan 4, 2005 | 12:04 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Well, not really!!
To HELP!! Column Lock Problem
