Quick borla stinger question
Old Jan 2, 2005 | 10:36 PM
servohead's Avatar
servohead
Default Quick borla stinger question
Planning on installing my borla stinger kit this coming weekend. My only question is, will I have the same problem as with the corsa indys where they loosen up, fall off, clamps break...etc. as I've read about? I thought the clamps that this kit came with looked plenty beefy for the job...
Old Jan 2, 2005 | 10:40 PM
n2spd's Avatar
n2spd
I have had Borlas for a while now and had no problems. I even went back and checked the bolts about three months after I installed them and they were fine. Good luck.
Old Jan 2, 2005 | 11:50 PM
Dave68's Avatar
Dave68
...same here. I've adjusted them once, but other than that, they've been perfect.
Old Jan 3, 2005 | 12:02 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Borla
Ive had Borlas on my car as well and really like them......They are a little loud because the cam and my stroker motor. You cant hear the D1SC
Old Jan 3, 2005 | 12:29 AM
tjkzo6's Avatar
tjkzo6
I've had mine on both my 01 Z and now the 03 Z with not even a lick of problem, let alone with looseness. When I added the long tubes and X pipe we loosened and readjusted the mounting angles but snug as a bug on this install.
Good Luck - you'll love the exhaust note!
TJ
Old Jan 3, 2005 | 12:31 AM
mdhmi's Avatar
mdhmi
No problems here with the 2 Tips.
Mark
Old Jan 3, 2005 | 12:43 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
no prob. here either
(but going to check next time up on the lift)
Rain
Old Jan 3, 2005 | 06:09 PM
servohead's Avatar
servohead
Well then. We know something now about these aftermarket exhausts don't we!! On the other thread recently posted on our forum concerning the corsa kits you'll see how much trouble those guy's are having with the clamps not working out properly, some of them even had to weld it together! However I'm happy to hear that the borla will stay together! Thanks guys!
Old Jan 3, 2005 | 06:28 PM
Gimmesum HP's Avatar
Gimmesum HP
I got hit in the left side rear and my 2 tips stayed on and only where slightly out of position. Now as for the rest of the rear and left panel that's another story.
To Quick borla stinger question
