Shift stick came off!!
Old Jan 8, 2005 | 03:09 PM
tixin's Avatar
tixin
Default Shift stick came off!!
I pulled up on the manual stick shift and the stick came off!
I don't think it is normal... is it? Thanks.
Old Jan 8, 2005 | 03:13 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
What came off?? the ****? the shifter and the ****? or the entire assembly and the rectangular plate that bolts to the top of the well area??
VR
Old Jan 8, 2005 | 03:55 PM
tixin's Avatar
tixin
The stick where the **** attached to came off. I was able to stick it back in and it seems to work normally. I have not removed the boot to see exactly what happened!
Old Jan 8, 2005 | 03:57 PM
99 The Hard Way's Avatar
99 The Hard Way
This happened to my 98 when i test drove it. The rubber insert which is used reduce vibration had com apart on the inside. The dealer replaced the shifter & all was fine. SCOTT
Old Jan 8, 2005 | 04:15 PM
quick99ls1's Avatar
quick99ls1
that would certainly give me a heart attack,
Old Jan 8, 2005 | 05:05 PM
Casem1's Avatar
Casem1
Default I am glad they come off
It is a handy feature when you have a tough time removing the T pin from the shifter (in the ****). Actually, I never did get the T pin out and short leather boot ready to go on with my Hurst, so the ****, top shifter shaft and stock boot are still one big assembly.
I guess the guy in Bowling Green who hammered the T pin in on my car was pi$$ed about something since my shifter shaft came off before the T pin came loose...
Old Jan 8, 2005 | 05:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That is a good excuse to get a new short throw shifter!!!!!!!!!!!! If you need assistance installing it, let us know.
BC
Old Jan 8, 2005 | 05:26 PM
Dave68's Avatar
Dave68
Default Go short-throw!
BC
I just installed my BPP shifter and like Bill, wrote a procedure to help those who have never done it before. You can find it at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave
Derek Zalewski's Avatar
Derek Zalewski
Forum Member (C5lvr) - had the same problem with this 1999 Corvette. He did buy a hurst to replace the stock unit. It is a good excuse to buy one.
Good luck,
Old Jan 8, 2005 | 06:56 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
good idea, i think i am going out now to blow my dif. so i can get my 4. 10's
Old Jan 8, 2005 | 07:38 PM
Cscokd's Avatar
Cscokd
same thing happened to me.. .I had to use a hacksaw and cut the stock **** off before I could install my Hurst shifter and short boot.
John
Old Jan 9, 2005 | 02:53 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I had the same problem on my '01. So at stop lights when people would look at me, I'd pull the stick apart and act like the car broke, just to play with people
To Shift stick came off!!
