Carbon Driveshaft
Check out www.peachstateposse.com for details.
http://www.peachstateposse.com/forum...pic.php?t=5244
the flex causes the aluminum drive shaft to start to whip like a jump rope. This deflection causes the rubber ends to make extreme heat which causes the failure.
This is why our carbon shaft was developed. It is rated to 8200 rpms with a 25% safety margin before deflection. that means that you can rev the engine ( and thus the drive shaft) to over 10,000 rpms( but that is truly in the margin)
There have been so many drive shaft failures that to just make a beefier coupler and call it "Good" is missing the problem.
I ran the entire World Challenge season on my Carbon shaft including many test days at the race track plus a day at the drag races where we ran 140mph in the 1/4 mile and destroyed 3 complete rear ends in the process.
The drive shaft came out looking like brand new.
Keep in mind that the Corvette Drive shaft is just an extension of the transmission input shaft. So it revs at engine RPMS all the time, in any gear. So if you rev over 6200 rpms you are in the margin with an Aluminum driveshaft.
What did GM do to solve the problem? They put a composite disc on the drive shaft as a rubbing block so that when the drive shaft starts to "whip" like a jump rope, this disc rubs on the inside of the torque tube and limits how far the stock aluminum drive shaft can deflect.
Just look inside your torque tube when you have it out and you will see the rub marks. Marks that can only be made if the shaft wabbles, or whips.
What you will have even with an improved rubber coupler or billit couplers is the energy from the whipping shaft will now go into your bearings and destroy them. Or it will destroy those upgraded rubber couplers just like the stock ones because it is not the radial strength that the stock couplers are lacking, it is what the forces do to a rubber coupler that has been moved from its original intended position.
Picture the input shaft clamped in a vice. then let the aluminum shaft hang down. that is what happens to the rubber couplers at high rpms. Just using stiffer rubber will not cure the problem, but it will just try to affect the symptom which is destroyed rubbers. The deflection will still exist with the aluminum shaft.
A carbon shaft is the only way available now to avoid drive shaft deflection. and deflection is RPM related. The rubber then loses strength and cracks, and they come apart on a launch or a hard accelleration. then the "acceleration" is believed to be the cause, not just the straw that broke the camels back.
thanks
Lou Gigliotti LGM
972-429-1963
I was thinking of doing this. I have the LG CF drive shaft and it is a quality unit
The LWA coupler is an interesting to solution for something more durable than the factory rubber coupler but allows some dampening which aluminum does not. The safety features are well thought out too. When my tq tube failed the input shaft moved forward damaging the splines on the back disk on a McLeod Street Twin and ate up the pilot bearing.
The only thing that I don't like is the steel plate on one side. that means that the give in the coupler is limited by how much angle deflection the front 3 bolts can flex or lean over.
Imagine if the rubber was not there, then the bolts would be held in place by the steel bushings molded into the rubber. When the torque is applied you can see how the steel plate will limit the amount of give the rubber coupler will have.
I think the LSA coupler will be a solution for those who have cracked stock ones but I think that without a Carbon Shaft the problems will just manifest themselves in a different way.
Just my .02
LG
I thought the same thing when I first saw the pics. The designer came out to a local Club Dinner last Friday night and passed around the production unit.
Mike
Mike
Lamar
Mike
The Corvette forum price is $1195. Sorry,
We have them for early cars now as well as mid 01 and up. (there was a change in 01. All Z06 cars got the larger driveshaft and some later Coupes did.
You just get the drive shaft. We only recommend one of the Aluminum couplers. the shaft needs some compliance to account for machine tollerances between the bell housing, torque tube and Transmission.
I ran the whole racing Season with both rubber couplers in place and had no problems.
The aluminum coupler is $99 Corvette forum price.
Lou G
You have one of these composite driveshafts for the A4 yet?
I have vibrations at ~3500 to 4500 rpm in N or D... dealer scares me with "it must be in the engine" which runs strong and very smooth at any other speed. I have felt that it is in the driveline somewhere.
