SS3600 Installation ?
Old Jan 14, 2005 | 11:19 AM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Default SS3600 Installation ?
What will I need to do after I instal the converter? Will I need to get a tune with LS1 edit? Can I do it with a Diablo Predator? Or, will it be fine like it is?
Old Jan 14, 2005 | 04:04 PM
MikeV's Avatar
MikeV
First thing is to verify that your trans fluid is at the correct level. . . very common mistake. Now if you did not install a trans cooler, watch your trans temps very closely as it will run HOT. Now. You need to remove torque management. I believe the Predator will do that, if not any tuner with LS1 Edit can do it. Good luck an have fun. Semper Fi.
Mike V
Old Jan 14, 2005 | 04:12 PM
Antvette's Avatar
Antvette
I already have a trans cooler and it will be installed. Now, I guess my problem is do I need to do anything special with the CPU besides remove the Torque Management?
Old Jan 15, 2005 | 09:35 AM
Antvette's Avatar
Antvette
So removing the Torque Managment is all I need to do for a Torque Converter install?
To SS3600 Installation ?
