Should I do Headers Next then Cam?
Old Jan 14, 2005 | 08:26 PM
Racie's Avatar
Racie
Default Should I do Headers Next then Cam?
I'm waiting on my Varaam Intake that I ordered today. I already put Corsa catback exhaust on. Should I put longtubes on next or cam, springs, and rods??? Thanks for any help...
Old Jan 14, 2005 | 08:47 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
I'd do headers first or cam and headers together if you can swing it! You will need a tune after the cam... you may be okay without one on the headers....at least until cam time....
Old Jan 14, 2005 | 11:42 PM
vetterlatethannever's Avatar
vetterlatethannever
I would reccommend headers first. You probably will not get the max out of your cam until you do the headers. Good luck!!!
Old Jan 15, 2005 | 02:00 AM
NVR BRNG's Avatar
NVR BRNG
Yeah, try to do the cam & LT headers at the same time, and get a dyno tune.
If you do the headers by themselves and no tune, your AFR could be lean, at a couple shops here in So. CA, on some before-tune dyno pulls, some cars are in the 14:1 range.
If you do headers only, once you select your brand, talk to a good tuner. Tell him your set up, brand of headers and ask him if you will be OK to run the car w/o a dyno tune. My guess is that if you do this, you will be lean, but the question is how lean.
Thus, Headers + Cam + dynotune (pay for it once)
imagine32000's Avatar
imagine32000
Headers first.
- Matt
Old Jan 15, 2005 | 07:58 AM
vettenuts's Avatar
vettenuts
I did headers first. Now I am cam shopping
To Should I do Headers Next then Cam?
