shift Knob
Old Jan 18, 2005 | 06:16 PM
breabob's Avatar
breabob
Default shift ****
My buddy has a 99 C5 6 spd. We are trying to swap out the shifter. How the heck do you get that t clip that holds the shift **** on, off?
Old Jan 18, 2005 | 06:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the plastic cap on top of the old handle. you will see a rectangler piece of metal. Grab it very tight with vise grip pliers and use a small hammer to tap UP on the vise grips. once you get the key out the **** will unscrew.
BC
Old Jan 18, 2005 | 09:04 PM
SteveL2's Avatar
SteveL2
See the following instructions, courtesy of forum vendor, Vette Essentials: Removal instructions
Old Jan 19, 2005 | 10:42 AM
Dave68's Avatar
Dave68
Use the following procedure for the easiest way I've found:
http://www.conceptualpolymer.com/corvette_install.htm
Note the type of vise-grip used. This is the key to avoiding damage to the ****.
Old Jan 19, 2005 | 09:36 PM
Perry Mason's Avatar
Perry Mason
Remove the "glass" roof before using the vice grips, just in case the tool slips!
Old Jan 20, 2005 | 12:57 PM
Avanti's Avatar
Avanti
A lot of ways available. I prefer to use a very small open-end wrench, one with the open end at about a 75-degree angle from the handle (not the more common 15-degrees or so), and lever out the pin. Less chance of damaging anything.
All the best.
Old Jan 20, 2005 | 03:12 PM
vetdude's Avatar
vetdude
also, try adding a few drops of WD40 where the "demon key" fits into the **** to help slipping it out.
Old Jan 20, 2005 | 11:59 PM
The Batman's Avatar
The Batman
You don't need to pull extremely hard or hammer hard. Just a steady tug and some firm taps and it'll move.
Old Jan 21, 2005 | 11:07 AM
stingray4me's Avatar
stingray4me
use a screwdriver on each side of it & it will pop off.
To shift Knob
