Smog Pump
Old Jan 18, 2005 | 06:45 PM
LAYNLOW's Avatar
LAYNLOW
Default Smog Pump
My "04" C5 went into the shop on Saturday.
I'm going with the ATI ProCharger along with a few other mods.
They called today asking if it would be ok to remove my smog pump.
I asked what the down side was and they said there wasn't any.
This is a top shop in my area so I'm going to trust their direction.
Let me know if you guys have any thoughts about this.
Old Jan 18, 2005 | 06:53 PM
BlueDragon's Avatar
BlueDragon
Mmmm hope you don't have to pass smog test. And yes she will kick off codes, I ***-u-me they know that and can disable the codes. Why do they want to remove it??
Old Jan 18, 2005 | 07:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The AIR PUMP (electric) runs at start up and allows the cats to warm up and light off faster. Most states do an underhood inspection and look for the AIR system.
Bill C
Old Jan 18, 2005 | 08:14 PM
IM QUIKR's Avatar
IM QUIKR
Bill C
It does no harm to leave it in, so I'd say no to the deletion. But if they do remove it they can edit it out in the programming and no codes will be thrown. It depends on you and the State you live in to how stringent they inspect your cars. Here in the Peoples republic of Illinois they plug into the computer and check for recent codes and no inspection.
Old Jan 18, 2005 | 08:18 PM
leaftye's Avatar
leaftye
It sure would help if you'd post what state you live in!
Old Jan 18, 2005 | 08:39 PM
T_Vert's Avatar
T_Vert
good luck finding it on a visual inspection! Its stashed under the front fascia and is impossible to get at or even see w/o the car in the air. You can fail 2 readiness tests in illinios and still pass the test. I have my smog pump gone and disasbled the codes w/ no problems. It actually cleans up the engine bay quite a bit to remove those air tubes to the headers.
Dave
Old Jan 19, 2005 | 06:34 AM
LAYNLOW's Avatar
LAYNLOW
Default Smog Pump
When I asked about removing it, and why, they told me it was not needed and was just more weight.
If I do decide to remove it and it becomes an issue I'll have them put it back on.
Old Jan 19, 2005 | 07:35 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The addition weight of the pro charger may be their concern. There have been some suspension issues with the addtion of extra weight on the front suspension.
Old Jan 19, 2005 | 07:48 AM
IM QUIKR's Avatar
IM QUIKR
ET, the pump does not weigh that much. In fact you can consider it to balance out the right side addition of weight with the blower. Seriously, I believe the installer just does not want to spend the time messing with it. Can you blame him? Stink'n EPA. Next, they will make us stop breathing to save the earth from CO2.
You gotta love "Earth day, " that's when all the Leftys get together and trash the city parks with a ton of litter.
Sorry for the editorial. I'll sit down now.
Old Jan 19, 2005 | 11:29 AM
BlueDragon's Avatar
BlueDragon
If you removed the pump and left the plumbing you might get past visual.
Here in Cali, you would need the plumbing and if the codes returned a zero rather than a valid code, you would fail they just changed here and actually run you on a low speed dyno, so without AIR, it is likely you will fail the exhaust sample also.
There is not a lot of weight a lb. or two to be saved by removing it. I have had mine out replacing the skid frame. I think they just don't want to deal with the plumbing.
Old Jan 19, 2005 | 01:18 PM
BHP's Avatar
BHP
You will fail the OBDII readiness tests. The air pump will show failed even if you try to turn it off with LS1-Edit.
Old Jan 19, 2005 | 07:51 PM
leaftye's Avatar
leaftye
15 lbs. At least that's the information in the C5 General Sticky.
Old Jan 21, 2005 | 02:38 PM
BlueDragon's Avatar
BlueDragon
Maybe with all the plumbing, but not just the pump. It is plastic and not a real big piece! I have had mine out and in my hand and I guarantee it ain't no 15 lbs.
Old Jan 21, 2005 | 03:15 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
I think the real reason behind removing the pump is that the left intercooler fits in the same area... probably a PITA to relocate.
Old Jan 21, 2005 | 05:09 PM
BlackMagicC5's Avatar
BlackMagicC5
I've had the pump in out in my hand. I'd say it weighs about 2lbs. It is a big pita to mess with it when doing a procharger installation. I just left mine out. As long as you wont have problems passing emissions, I say take it out and turn the codes off. If its not doing anything, why leave it in?
To Smog Pump
